20 Most Recent Sentry Fire Safe - Safe - DS3607 Questions & Answers
Csw 4747 sentrysafe
4/25/2016 5:46:25 PM • Sentry Fire Safe... • Answered on Apr 25, 2016
How can i stop my sentry safe from beeping when i
I have a 1459E model sentry safe. I was having the same problem. I removed the front electronic assembly, easily removed the circuit board, located the annoying beep speaker, then fliped the board over and heated up the two solder pins holding the speaker to the board, then it easily pulled away from the board. Speaker removed, I then op tested it by plugging it back the way I took it out......and voila! NO BEEPING!!! YES!!!
6/2/2014 5:26:56 PM • Sentry Fire Safe... • Answered on Jun 02, 2014
Im staying in a hotel and they have a safemark systems safe in the room and everytime i try to put my password in it says batt-h what do i do
That means that it is low on battery and does not have enough power to lock.
6/1/2014 4:07:55 AM • Sentry Fire Safe... • Answered on Jun 01, 2014
How to put batteries in ds3607
a1 locksmith advised me to Remove and discard the screw (if equipped) at the base of the lock case. 2. Turn the electronic lock case to the right (clockwise), from 12 o'clock to 2 o'clock, and remove. • Insert 4 new AA batteries (not included) to power this lock. • Replace the electronic lock case and turn to the left (to 12 o'clock) to reassemble. NOTE: The yellow LED will light when the batteries more info at sentry safe sales service
11/23/2013 6:43:24 AM • Sentry Fire Safe... • Answered on Nov 23, 2013
2answers
Csw3607 sentry safe will not open. when i use my 5
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
11/5/2013 7:22:19 PM • Sentry Fire Safe... • Answered on Nov 05, 2013
Changing your safe code
here is the user manual for the safe http://www.sentrysafe.com/pdfs/OwnersManuals/513022.pdf
hope this helps.
7/23/2013 3:22:04 PM • Sentry Fire Safe... • Answered on Jul 23, 2013
0answers
For got code
If you registered your safe when you purchased it go here to recover your combination.
If you did not register your safe after you purchased it click here and follow instructions on recovering your combination.
After recovering your combination be sure and register it here so next time you will have easy access in case you forget it again.
If none of the above options have helped you will need to Email or Call customer service directly.
5/26/2011 6:48:01 AM • Sentry Fire Safe... • Answered on May 26, 2011
I have my combination code I can't remember
It should be left, right, left
5/16/2011 3:47:37 AM • Sentry Fire Safe... • Answered on May 16, 2011
Sentry Fire Safe -  Safe - DS3607 Logo
46 questions posted
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Sentry Home Security
Most Popular Question
stop sentry safe from beeping when
  • Home Security
