20 Most Recent
Philips 47PFL5603D 47 in. LCD HDTV Questions & Answers
Philips 47pfl5603/27 will not turn on
what about the push button power switch ,join the wires across and try that ,most common fault is these switches the spring mechanism inside stops pushing the contacts together
2/2/2012 3:54:37 AM •
Philips...
Answered
on Feb 02, 2012
Breaker went out for a second then came back
Yes,the tv fuse in the tv power supply board,that the board where the tv power a/c cord plug into it.Tries tv unplug,replug it back like about an hour later.For the tv to do a resetting it back to the factory setting,tv now should be working again.If not,the tv power supply board might be just dies all together.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
6/17/2011 9:56:42 PM •
Philips...
Answered
on Jun 17, 2011
Philips 47PFL5603D LCD TV ,will
The power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
5/13/2011 9:46:45 PM •
Philips...
Answered
on May 13, 2011
My dish network remote or philip remote will not
Hey randallbmtk,my name is Mike Houston of DISH Network and I was reading over your post andsee that the DISH remote will not work the Phillips TV. There are some steps toget this remote programmed to your TV, we have what we call a Power Scan and itwill find the right code to your TV so you can turn it on and off. I will sendthe link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
4/17/2011 7:04:49 PM •
Philips...
Answered
on Apr 17, 2011
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007 Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted
3 years ago
Guest
- Rank: Guide
- Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me. Add a comment
WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
Comment:
11/28/2010 2:11:57 AM •
Philips...
Answered
on Nov 28, 2010
I accidently plugged something into
The Service UART is used to make internal adjustments or updates to your tv. It is intended to be used by service technicians only.
Since you accidently plugged something into it, it's possible that an internal component has been damaged. Your best option is to call a tv repair shop have have a technician check out your tv.
Hopefully, your tv hasn't been damaged and the tech can get it working again. At the very least, the tech will be able to tell you exactly what's wrong with it and what it will cost to repair it.
8/14/2009 3:01:35 AM •
Philips...
Answered
on Aug 14, 2009
The remote control of my
The IR Reciever is faulty if it is an 08' model, the serial number will indicate the manufacturer's date of production. The digits 5,6,7, and 8 are the keys. 5 and 6 is the week of the 78 year.
Have a technician replace the IR Board to solve the problem.
6/18/2009 10:43:06 PM •
Philips...
Answered
on Jun 18, 2009
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
