20 Most Recent Onkyo TX-SR806 Receiver Questions & Answers
I have a Onkyo TX-SR806
Hi The HDMI board needs to be serviced or changed. nothing you can do. Regards
9/9/2019 8:59:46 AM • Onkyo TX-SR806... • Answered on Sep 09, 2019
My reciever went to protect mode after my speaker
Yes, you can do this easily.
Perform the following steps
(1)Plug your amp to AC outlet.
(2)Switch it on.
(3)observe time taken for switching off.
(4)immediate to shut down over current protect(5)3 seconds to shut down DC protect.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download NR806 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
11/24/2017 8:47:39 AM • Onkyo TX-SR806... • Answered on Nov 24, 2017
My Onkyo TX-SR806 remote has
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
7/11/2017 4:21:00 PM • Onkyo TX-SR806... • Answered on Jul 11, 2017
0answers
No sound
Be the first to answer 3/2/2014 8:30:40 AM • Onkyo TX-SR806... • Posted on Mar 02, 2014Be the first to answer
0answers
0answers
3answers
I have a Onkyo TX-SR806 HDMI output does not work
Sounds like you may have a bad HDMI card my friend. I had an issue with my HDMI card that was causing blue dots to appear on the dark parts of the screen, when outputting 1080p over HDMI. This is a rather common issue, so it wouldn't surprise me if your HDMI board needs replacement - especially if you've ever experienced the infamous blue dot issue.
1/13/2013 9:15:40 PM • Onkyo TX-SR806... • Answered on Jan 13, 2013
I have onkyo receiver SR806 7.1 channel . I bought it last year and got it hooked 3 month back. Since last week its not transmitting Picture to my LED T.V through HDMI . When I pull power plug and put
If you have warranty left I would encouage you to use it because you clearly have a problem, the cable has been changed along with connections checked. The only other thing is check your setting carefully on both units to ensure nothing was missed, "owner manuals would be handy"
3/29/2012 12:58:19 AM • Onkyo TX-SR806... • Answered on Mar 29, 2012
Onkyo txsr806 keeps on going into standby
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
7/6/2011 2:41:01 AM • Onkyo TX-SR806... • Answered on Jul 06, 2011
I bought a Onkyo TX-SR806
Unless you are good at soldering have the parts on hand and know exactly what you are looking at, it will be very difficult for you to fix it yourself.
3/20/2011 2:39:36 AM • Onkyo TX-SR806... • Answered on Mar 20, 2011
I need to find my nearest onkyo repair centre for
http://www.onkyousa.com/locator.cfm
or any radio shack can send it to their service center.
3/13/2011 2:03:39 AM • Onkyo TX-SR806... • Answered on Mar 13, 2011
Onkyo TX-SR806 Receiver Logo
34 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
onkyo tx sr806
  • Audio Players & Recorders
