20 Most Recent
Fujitsu fi-6130 Flatbed Scanner Questions & Answers
Error ds41003
I have that problem with my fi-6130 too, but the message specifically states "abnormality has occurred during communication." So the comments on paper jams (which I've not had) appear to be wild guesses unrelated to whatever is actually happening. But those messages are very old, so apparently their system is guessing what answers to throw at a question it cannot handle....
I need to copy a word document however when I scan
Make sure you installed the full software suite for your scanner. Scanners do scan to image files but should come bundled with Optical Character Recognition (OCR) software. Select the OCR option in your scanner settings and it will convert your scans to an editable format. Take note, OCR software is only as good as the scan, and the content on the paper, so it might make some mistakes, in which you will have to manually fix in Word etc "proofing"...
Regards,
Chris
Fujitsu scanner Fi6130 H8
Windows sends a message that does not recognize the connected device and sometimes if it recognizes
My fujitsue fi-6130 stopped automatically scanning both sides
You can try a 'hard reboot' of the unit by unplugging it while it is running, wait a minute or so and then restore the power.
With most electronics this forces a 'self-diagnostic' program which might fix the problem. Another option is to delete and them reinstall the software with a disc or online. Make certain that you have your machine set to automatically check for updates if it is connected to the Internet.
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
