20 Most Recent
Tomtom ONE 140 GPS Receiver Questions & Answers
I have not got a
you can download it by clicking
here and print it out if you wish, tho bookmarking the page may be a good idea.
Its not starting and has
Try rebooting system. Turn off like normal, but when you turn on, hold down on button and keep it down continuously the way through the starting up process, for at least 15 seconds then let go. Let me know if it helps.
We recently purchased a Tom
Try a soft reset first - hold the on button down for 20-25 seconds to do this. Most of the time this will fix starting issues.
If the tomtom still won't start you need to connect to your computer via usb cable and start tomtom home (downloadable from the tomtom website) - an auto update should fix it if the tomtom is recognised.
If tomtom home cannot recognise it (shows no device connected) contact tomtom customer support who will send you a software reset - then eventually you wil be back up and running!
How do I change language to english on tomtom 140
Do this whilst it is disconnect from a PC
Whilst it shows a map display touch the screen once.
Select the icon that looks like a spanner / wrench
Use the right arrow on the display until you see a bunch of flags. (if you shoot past it just keep going until it comes around again)
Touch that and select the correct the correct flag / language
Hope this gives you the information you need
Please rate me 4 thumbs for the free answer
When switched on green light next to switch flickers but that is all
It sounds like the TomTom isn't able to boot up. This may be due to a software or data issue.
Have you tried to (use HOME on your computer to) connect to the TomTom server ? to update the software/data, and/or tried to restore the software / data with the (previously) backed-up copy (that you had previously saved on your computer) ?
How can I set time?
You can set (or reset) your Time (& display format) using the "Menu".
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
1. To set Time:
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
How do I update maps on tom tom one from computer to GPS ?
Usually, you connect your TomTom to your computer, and use the TomTom software (e.g. HOME) to update (e.g. buy, download and install) your map(s).
If your question is about how to copy a (new / another) map on your computer to your TomTom device (i.e. without using the TomTom HOME software), you can simply copy the "map" folder (of the map on your computer) to your TomTom Device (that you've connected to your computer).
You may have other questions like, is there enough memory on your TomTom device for the map ?; is the (new/other) map version compatible for the TomTom (model/version) device that you have ?; is the map "activated" to run on your TomTom device? etc.
