20 Most Recent
Samsung DVD-H1080 DVD Player Questions & Answers
I have bought samsung dvd player h1080 and it
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
8/23/2011 6:17:58 AM •
Samsung...
Answered
on Aug 23, 2011
How to unlock the samsung dvd h1080?
SAMSUNG DVD-H1080
This worked for me:
Turn on the DVD without disc in the tray
Press repeat (not repeat a-b)
Press fast forward (>> not >>l)
Press rewind (<< not l<< )
Press up
Press down
'0' appears in top right corner
turn off then back on.
8/23/2011 6:15:49 AM •
Samsung...
Answered
on Aug 23, 2011
I got a new Samsung
If a new DVD player ur tv dose recgonises the DVD disc and not reading the DVD disc,it might be dirty or scratches and cracks on the DVD disc itself.Tries It with other DVD discs,if have the same problems,than it is the DVD player itself,newly bought,yes return it get another one.
12/15/2010 7:41:30 PM •
Samsung...
Answered
on Dec 15, 2010
Our Samsung DVD-H1080 DVD Player
Are you using the remote or touch button on case to eject tray?
Sometimes the top lid gets warped and prevents the tray from opening. Press eject and lift the front part of the lid at the same time.
8/18/2010 3:18:36 PM •
Samsung...
Answered
on Aug 18, 2010
Unlock region code for Samsung DVD-H1080
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Hope this gives you the information you need
Bob
EX Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
PS. If you dont find it on there then a google search for "region free" will probably get you other sources but AVOID any that want money as there are plenty of FREE sites out there that do this.
5/16/2010 3:31:50 PM •
Samsung...
Answered
on May 16, 2010
Samsung DVD-H1080 DVD player Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click
HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click
HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit
Samsung's official website.I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
I need the multi region code for a Samsung DVD
Sorry, there isn't one. Your model is not hackable.
The usual Samsung hacks involve using the remote to enter the correct numbers but your model has no number keypad on the remote. Substituting a universal remote also does not work and I've been informed by Samsung that the region coding on this model is hardware encoded just like on many Sony and Panasonic models so you cannot even override the coding using a service centre remote control (I've tried). I discovered this when a friend purchased a large quantity of clearance overstock region 6 DVD H1080's and asked me to convert them for resale in the UK (region 2).
To hack your model requires internal hardware replacement and this is not economically viable.
10/14/2009 11:15:27 AM •
Samsung...
Answered
on Oct 14, 2009
Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
8/12/2009 12:52:25 PM •
Samsung...
Answered
on Aug 12, 2009
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
3 days ago
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
