20 Most Recent
Casio GShock Riseman AltiTherm GW92001 Watch Questions & Answers
I have a g shock riseman g-9200, what does the
PS means the watch is in power save mode if there is an indicator under the PS on your watch. this means the watch will go into a sleep mode when it is left in the dark for extended periods. change this setting by holding the top left button until a city code starts flashing, then press the bottom left button until "PSON" is flashing , you can switch between "PSON" and "PSOF" in this way by pressing the bottom right button. i, and casio recommend leaving the watch in the powersave mode though to help extend battery life. I got all this info from my G Shock manual.
Will not recieve atomic time.My other casio atomic
This watch will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it's self change location in your house. It receives the signal at 0200 0400 and 0600 for the correction.
The transmitter is located in Fort Collins, Colorado. this station transmits the time
codes and is best received at night.
Hope this tip helps
David
I have several of the both watches and clocks and love them.
I have a casio g-shock not work the Altitude Measurement
The riseman can be reset but also needs to be calibrated. Your instruction manual will walk you through calibrating your altimeter.
If you have misplaced your manual you can download a manual from Casio's website.
http://support.casio.com/manual.php?rgn=1&cid=002
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
How to fix Quartz on my casio 708 mtp 3036
This is a job a specialist watch repairer should do. It will need specialist tools so if you are not familiar with working on watches pay someone to do it for you. Also consider the cost of repair. It might be cheaper to simply buy a new watch.
