20 Most Recent
GE Monogram ZE2160SF Convection / Microwave Oven Questions & Answers
Opening the door tripped breaker a few times, now microwave will not power on.
Sounds like a bad switch should have three primary, secondary, and monitor switch after 5 years change all 3 they are not the same primary and secondary are NO ( normally open ) and the monitor NC ( normally closed ) unit will not come on the fuse on the filter board is blow this usually shorts out the filter board change the switches first and replace fuse may not have to replace filter board hopes this helps.
Paint flaking under glass plate
had three times replacement because of the same problem. Finally GE got me a ZE2160 SF05 model which has been have no such problem for three years.
How to change the lightbulb ze2160sf01
I found the following info: Hope it helps>
" I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved "
