20 Most Recent
Roxio Creator 2009 Ultimate for PC Questions & Answers
When i go to control
Could be a software glitch.
Follow the steps recommended by the manufacturer of your computer.
98% of them put PDF files online for this very purpose.
Windows 8.1
You will have to buy a newer version of Roxio creator.
No permissions to launch application
I had this problem and searched high and low for an answer. This worked for me: http://kb.roxio.com/search.aspx?URL=/content/000243CR&PARAMS=set-locale=en
Where do i find the serial number for installing
If you purchased the software at a retail store, they should have supplied the serial-number, as part of the package. Take it back, and have the sales-clerk show you where the serial-number is located.
Or, access
http://www.MajorGeeks.com and find "AShampoo Burning 6 Free Edition" -- this is _free_ software, just as good as NERO, and it does _not_ require a serial-number.
Create DVD's gets no permissions error
Go to your control panel and to your accounts. Look at your account on the computer, make sure your account is administrator and not limited account. as a limited account, you generally have few application permissions if not leave a comment that it is still having issues and i shall do some research >.<
My computer hangs up
as it is an HP DV6000, with known motherboard issues, I would suggest try running a few other programs also and see if they hang as well.
I cant launch nothing
Use 'Add/Remove Programs' to uninstall ROXIO.
Then, access
and search for 'AShampoo Burning 6'.
This is _free_ software for burning CD/DVD disks,
and it works as well as the ROXIO software.
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Cannot launch roxio creator 2009 using desktop
If you are running any version of Windows, it's an easy fix, don't worry-
- Delete your desktop icon
- Using Windows Explorer, go to your C:\Program Files\Roxio folder
- Open the Roxio folder, and find the Creator.exe file
- Right click on the .exe file, 'create shortcut'
- Cut and paste the shortcut you just made onto your desktop.
- Try it to make sure it functions correctly.
I inadvertently deleted the Line-In Realtek High Definition Audio
Simply re-install the software and all your original data will be restored. If you purchased a downloaded version, go to the site from which your purchased it and request your keycode again, and permission to re-download. Then burn the text file with the keycode and the downloaded installer onto a CD so you won't lose it again. Another solution is to get Nero.
Roxio 2009 will not install on Vista Business
You should clean uninstall the roxio from the computer and then install it later. Please follow the link given below to uninstall it first.http://kb.roxio.com/search.aspx?URL=/content/kb/WinOnCD/000207CR&PARAMS=set-locale=enhere are the system requirements for roxio 9:http://kb.roxio.com/search.aspx?URL=/content/kb/Creator/000199CR&PARAMS=visit this link as well:http://kb.roxio.com/search.aspx?URL=/content/000217CR&PARAMS=set-locale=en
