20 Most Recent
Jl Audio 1000/1V2 Car Amp Questions & Answers
Why is jl audio 1000/1v2 in thermal but not hot?
They might be using the light to show other problems as well. Or the unit you bought has the same issue??
Double check all your connections, leave it unplugged for 24 hours after hitting the power button several times to drain the capacitors to hopefully clear any codes in the modual.
5/15/2014 4:05:31 AM •
Jl Audio...
Answered
on May 15, 2014
I have a jl audio
The low voltage light would indicate that there is not enough power reaching the amplifier through the power wire. Are you using 4awg or bigger wire? Is the amp grounded well? Does this happen all the time or just at high volume?
Try checking your power and ground connections and ensure that you are using the correct size of wire.
3/12/2011 10:45:33 PM •
Jl Audio...
Answered
on Mar 12, 2011
AMP READING LOW VOLTAGE
i have found that if your battery isnt almost brand new, it cant power an amp 2000w or higher. replace it. if not that then you may have to small of a power supply or ground wire. if not, well, your amp is bad. + remember ground wire cant be longer then 3 feet. good luck.
7/18/2009 1:38:48 AM •
Jl Audio...
Answered
on Jul 18, 2009
