20 Most Recent
Samsung DV448AGE Gas Dryer Questions & Answers
Dryer squeaks & vibrates
check the rollers and tensioner as well as the bearings, may even have worn glides or seals on the drum
Gas dryer not spinning
who is ned? there are no relays in this model. check the switch near the idler arm.. 1-12 here....http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV448AGPXAA0000/1482/0151200/50039879/00005?blt=06&prst=&shdMod=
Drum will not spin
While most Samsung dryer component failures will generate a trouble message on the display, a failure of the hi-limit thermal protector won't. If the hi-limit thermal protector has opened, it directly interrupts power to the drum motor. As a result, you can start a cycle using the buttons, the 'brain' will turn on the relays controlling the motor ( the faint clicking sound ) and run the cycle timer, but the motor can't actually run. And without drum rotation being sensed, the burner won't turn on either.Solution is to replace the hi-limit thermal cutout, which is located on the 'nose' of the blower assembly next to the dryer temperature control thermistor ( which is slightly larger than the hi-limit thermal cutout ).Also note that the usual cause of a hi-limit thermal cutout failure ( or a thermistor failure ) is ducts restricted by lint ... both the burner exhaust duct as well as the blower intake duct. Both should be disassembled and thoroughly cleaned while you have the dryer apart.
Samsung#DV448AGW/XAA check filter light on
Hello. #1-Use a vacuum cleaner with hose attached and vac the drum vent screen inside the drum. #2-disconnect AC power(unplug or switch off 220volt breaker) carefully remove hose from air duck of dryer and vac inside of dryer. Vac the hose and exhaust port. Reattach hose, reconnect AC power and test operation. #3-Problem still present the exhaust sensor or the (most likely) the exhaust fan not working properly. Good Luck!
Samsung DV448AGE / DV448AGP /
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
We recently moved. Ever
What you need to check is if the venting the dryer connects to is crushed/restricted or in some manner blocked. Check from where it connects at back of dryer all the way to where is vents outside of the house.
Gene
I have a dv448agp dryer
You will need to disassemble the entire front panel to get access to 2 other screws inside. Remove the top panel first, then the control panel and then remove the front panel.
