20 Most Recent Samsung 7.3 Cu. Ft. Electric Dryer Questions & Answers
I have a Samsung electric dryer, it wont run currently. It has a symbol, a grid with a wisk broom in front of it. What does this symbol mean and how do I fix my problem?
The dryer has an hour glass symbol on it and won't dry ... Anybody know what this is ?
10/10/2016 3:06:06 PM • Samsung 7.3 Cu.... • Answered on Oct 10, 2016
Breaker is triping out
a dead shirt in the wires , control board or element have an accredited service electrician check it out
11/20/2015 4:12:39 AM • Samsung 7.3 Cu.... • Answered on Nov 20, 2015
Model DC68. Why doesn't it start/spin?
bad door switch
7/29/2015 6:27:23 PM • Samsung 7.3 Cu.... • Answered on Jul 29, 2015
It is not getting hot
Need heater right hand side in bottom open front panel
2/24/2015 5:08:33 PM • Samsung 7.3 Cu.... • Answered on Feb 24, 2015
My dryer stopped working. it has power but when u hit run it does not turn on. is there a way to fix it?
Check the door switch and be sure it's working.
2/10/2015 6:58:20 PM • Samsung 7.3 Cu.... • Answered on Feb 10, 2015
4answers
Samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: [email protected]
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
8/5/2014 1:51:21 PM • Samsung 7.3 Cu.... • Answered on Aug 05, 2014
I am trying to replace the belt on my front load Samsung dryer model dv419aew/xaa
you will need to pull the top to gain acces to the control panel which you will remove to get to the screws on the front and go from there
3/24/2014 3:23:53 PM • Samsung 7.3 Cu.... • Answered on Mar 24, 2014
Samsung dv4006 control panel removal
remove the top with 2 screws on the back then slide back a little then it will lift off. there are 3 or 4 tabs at the top of the console that lift and the plastic will tilt toward the front and lift off to expose the control.
3/14/2014 10:27:41 PM • Samsung 7.3 Cu.... • Answered on Mar 14, 2014
Dryer runs fine but will stop without warning and will not power up after it stops
There might be something wrong with the heating.
1/31/2014 3:10:39 AM • Samsung 7.3 Cu.... • Answered on Jan 31, 2014
Runs but will not heat
The heating element is "open" (burned up) or one of the safety sensors that protect it from overheating is damaged (open).
12/31/2013 8:16:54 PM • Samsung 7.3 Cu.... • Answered on Dec 31, 2013
Samsung dryer DV419AEW/XAA belt parts number and how to replace?
You can find helpful exploded view diagrams and order parts by entering your part number or the full model number from the tag on the oven here.
12/28/2013 9:14:25 PM • Samsung 7.3 Cu.... • Answered on Dec 28, 2013
3answers
Have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
12/2/2013 10:35:07 PM • Samsung 7.3 Cu.... • Answered on Dec 02, 2013
Dv210aew/xaa
odds are the heating element opened or the hi limit or the safty thermostat
10/31/2013 12:35:22 AM • Samsung 7.3 Cu.... • Answered on Oct 31, 2013
I have a Samsung DV350 AG gas dryer, push start
can you hear motor running,if not maybee a sensor,something with door switch?
10/29/2013 10:07:51 PM • Samsung 7.3 Cu.... • Answered on Oct 29, 2013
Samsung 7.3 Cu. Ft. Electric Dryer Logo
114 questions posted
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
View Most Popular
Samsung Dryers
  • Samsung Dryers
Most Popular Question
am trying replace belt front load
  • Dryers
