20 Most Recent AMD MicroStar MS-5191 Socket 7 mATX Motherboard w/ Video - MS-5191 Questions & Answers
2answers
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.I would suggest using one the LED lights with two wires.(3-wire is a dual color LED)There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.HarDDrive activity LED, and Reset Switch are on the opposite row.Speaker has 4-pins designated for it. All the others use 2-pins.(Unless the PWR ON LED is a dual color jobbie)Touch two pins next to each other, in the same row; with the 2-wire LED.Start with finding the Power On switch first.Usually the top row 1st two pins are Power On LED (Light)Next in line are the 2 pins for the Power On switch.Bottom row 1st two pins are usually HarDDrive activity LED (light)Next 2-pins are usually Reset switch.May not apply to a motherboard old enough to use a Socket 7 processor socket. There may be 18 to 20-pins.Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.May be two separate Front Panel headers.Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)LED stays on? You have the Power On LED (Light) pins.LED blinks? HarDDrive activity LED (light) pins.Computer restarts? Reset switch pins.Look for abbreviations near the pins in the Front panel header.PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.HDD LED, and HDD are two for the HarDDrive activity LED. (Light)(If it states HDD SW it is the Power On switch. Weird old way of marking)RST, Reset, and RSW, are for the Reset Switch.(Reset Button)If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.(Original Equipment Manufacturer)Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.Regards,joecoolvette
1/5/2016 8:12:57 AM • AMD MicroStar... • Answered on Jan 05, 2016
How can I get User manual for AMD Desktop Motherboard AM2, DA061L-3D, 48.3BU01.01M, 09178-1M U
I would try the AMD web site. If still available, you will find one there.
6/29/2021 6:50:31 AM • AMD Computers &... • Answered on Jun 29, 2021
I just installed a motherboard because my video went out and the Onboard as well as the video card would not connect. I installed a power supply, new memory, new cpu, new hard drive, new video card and when all that failed still I installed a new motherboard. Still not connecting to the monitor. What am I missing? Here are my specifics. Upgrades Motherboard Foxconn A74ML-K AM2+ AM3 740G Motherboard AMD DDR2 MicroATX SATA PCIe x16 Phenom Video Card Dell ATI Radeon HD 4350 512MB DDR2 PCIe VGA DVI HDMI Graphics Video Card 0P002P Power Supply Apevia BT550W Beast 550W ATX Gaming Power Supply, Supports Dual/Quad Core CPUs Hard Drive Seagate BarraCuda 2TB Internal Hard Drive HDD – 3.5 Inch SATA 6Gb/s 7200 RPM 256MB Cache 3.5-Inch Dvd rom LG Internal 24x Super Multi with M-DISC Support DVD Burner  USB Card FebSmart PCIE 4-Ports Super Fast 5Gbps USB 3.0 Wifi adapter USB WiFi Adapter – 1200M WiFi Dongle High Speed 802.11ac 5dBi Dual Band 2.4/5GHz  Memory LEVEN DDR2 4GB (2GB×2) 800MHz PC6400 Unbuffered Non-ECC UDIMM 240 Pin CPU AMD Phenom II X3 710 2.6Ghz Processor Cpu Cooler Cooler Master CM12V Ultra Silent 8032 Fan Dimensions: 80x80x32 MM Voltage: DC 12V Speed: 2000 RPM Air Flow: 32.5 CFM Noise: 18 dBA Feature: Very Quiet & Long Life Span, Speed Sensor (Tach) Termination: 3-Pin / 3-Wire / 7.5-Inch After my new build would not boot properly I thought it was a video problem and was all ready to rma it. I specifically checked the manual for proper placement of the cmos jumper before I assembled it after reading of other peoples problems with the jumper left in the "clear" position. That's what I get for reading the manual. The jumper was actually placed correctly from the factory. The manual was wrong. -2 eggs for poor documentation and the headaches to find and fix the problem.
Perhaps the monitor is faulty? Did you check that with a device known to work. Listen to Larry though, he is the Hardware Guru here at Fixya.
4/8/2021 11:34:28 PM • AMD Computers &... • Answered on Apr 08, 2021
I have a windows 7 desktop 64bit, amd sempron LE-1200, that reads usb2.0. how do i get it to read a usb3.0 flashdrive without corrupting files when moved on it
USB 2 and 3 are the data speed capability of the interface it is possible to connect a USB3 flashdrive into a usb2 socket all that will happen is the files will transfer slower than on a usb3 socket. Hope this was helpful.
5/14/2020 11:25:53 PM • AMD Computers &... • Answered on May 14, 2020
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
3/20/2019 5:10:23 PM • AMD Computers &... • Answered on Mar 20, 2019
I have an AMD Athlon 64 X2 Dual Core processor running on Windows 7 32 bit. Can I install Windows 7 64 bit oS on this system?
yes but fresh install will be needed.back up important docs first
12/15/2018 8:53:13 PM • AMD Computers &... • Answered on Dec 15, 2018
yes you can. Win 7 win8 win 8.1 are no supported by Microsoft, only win 10.
12/15/2018 8:29:15 PM • AMD Computers &... • Answered on Dec 15, 2018
Hi i just joined and im so clueless what im goin to do amd where and how to statt Please i need your help someone pls! Thank you
on the ask a question page , type in the make , model year, type of equipment and the problem that you have and post it
4/30/2018 5:02:16 AM • AMD Computers &... • Answered on Apr 30, 2018
Have a smartab st1009x amd want to attach a wired mouse. Also, when typing in various progams it will skip to different lines or pages
Had this problem on a touchpad. Solved by downloading touchfreeze Check if touchfreeze has software for your OS
11/17/2017 12:16:22 AM • AMD Computers &... • Answered on Nov 17, 2017
On my Back-ups ES 550 the "Building Wiring Fault"
This red light usually indicated the ground on the outlet the UPS is connected to is not properly connected to ground. It could also mean the ground and neutral wires on the connected outlet are reversed.
11/1/2017 8:07:33 AM • AMD Computers &... • Answered on Nov 01, 2017
0answers
Computers & Internet Logo
Popular Tags
1 questions posted
Top AMD Computers & Internet Experts
ExpressFiX
ExpressFiX
NOEL
NOEL
john h
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AMD Computers & Internet
Most Popular Question
front panel connections
  • Computers & Internet
