20 Most Recent Craftsman Garage Door Opener 1/2 HP Chain Drive Questions & Answers
My Digi ii Garage door make a grinding sound at the motor when it opens .
GDO has failed and tie to replace it.
6/13/2023 6:39:11 PM • Craftsman Garage... • Answered on Jun 13, 2023
Craftsman HBW1127 Garage Door Opener. What replacement remote works with it please?
Question edited for a lot more clarity. Question moved from Televisions category. Contact some of the companies in the link. You may be able to get the old one repaired if it is truly obsolete.. https://www.google.com/search?q=craftsman+hbw1127+remote+replacement ..
12/9/2022 6:10:28 PM • Craftsman Garage... • Answered on Dec 09, 2022
Garage Door Opener - hums for 2 sec, no motor action; what else could be wrong?
From your description the motor is bad. The opener was made by chamberlain and you can bu a new opener at HD. I had 2 Craftsman openers in my garage and repaired them, but realized it was time to replace them with chamberlains and never regretted it.
12/6/2022 9:01:15 PM • Craftsman Garage... • Answered on Dec 06, 2022
2answers
I need an instructions manual for a 1999 craftsman 53650 model opener.
contact the person from whom you have bought it.......
11/15/2021 3:13:25 PM • Craftsman Garage... • Answered on Nov 15, 2021
2answers
My remote sends a signal, the opener indicator flashes, but the door does not open?
The learn button is located on the garage door opener unit itself that hangs from the ceiling. If you follow the gray antenna up to the unit you will see a red/orange button on the unit. That is the learn button. When you push that button and amber LED will light up either above or next to the learn button. This indicates that the garage door opener is now ready to learn a new device. Press and hold the button you want programed on the garage door opener remote and release it. The garage door opener will click and the garage door opener light will go off and come back on (if the light bulbs are in working order). The amber LED will go out, repeat if you need to program anything else.
4/3/2019 9:09:03 AM • Craftsman Garage... • Answered on Apr 03, 2019
Liftmaster 1/2 pro will only go in one direction then if u try to reverse it it just wont go
Im assuming the up position works. Try change all batteries and check sensors they can be off by a hair
4/3/2019 9:04:52 AM • Craftsman Garage... • Answered on Apr 03, 2019
3answers
How to repair a craftsman garage door opener
What exactly is the problem?
10/8/2018 11:23:33 PM • Craftsman Garage... • Answered on Oct 08, 2018
Sears garage door won't close, only goes about a foot then returns, I checked infrared -nothing is in way.
The dial is the force adjustment. if it ever does it again and the light on the opener isn't blinking, its a bad rpm board
3/17/2016 12:26:24 AM • Craftsman Garage... • Answered on Mar 17, 2016
How do i contact craftsman co and ask a question about a garage door opener
save time and go on youtube
3/17/2016 12:23:38 AM • Craftsman Garage... • Answered on Mar 17, 2016
2answers
Remote openers wont work unless inside gerage
Possible bad battery. Or there is some type of radio frequency interference coming from somewhere around your house.
3/17/2016 12:22:25 AM • Craftsman Garage... • Answered on Mar 17, 2016
2answers
I need a gear for FCC ID : HBW1127 craftsman garage door opener 41A4315-7C, what is the part number?
This is the one you will need. Best place to buy is from Amazon if you are going to do it yourself. http://www.amazon.com/Chamberlain-LiftMaster-Craftsman-41C4220A-Sprocket/dp/B006L8CZKI/ref=sr_1_1?ie=UTF8&qid=1424440429&sr=8-1&keywords=craftsman+gear+kit
8/26/2015 2:23:34 PM • Craftsman Garage... • Answered on Aug 26, 2015
We have installed the craftsman garage door opener and have continually adjusted the up and down travel limits and the door will not stay down
try adjusting the down force. the force necessary to may it reverse. it may be set too light. increase the down force and see if that helps. usually screw in back of unit. and usually labeled.
7/25/2015 5:40:41 AM • Craftsman Garage... • Answered on Jul 25, 2015
2answers
Why does the overhead light on my garage door opener go off & on without any reason, day or night, even when door is not in use?
There's a gremlin living in your overhead light.....lol. The circuit board in the opener has the timer for the light. There's a component that's beginning to fail on it. Replace the circuit board.
7/7/2015 4:08:31 AM • Craftsman Garage... • Answered on Jul 07, 2015
The power went out in a storm,now my garage door opener won't work.The learn button keeps blinking
There is an chance you circuit board got a surge. It may need replaced. First try unplugging it for 30 sec and plugging it back in. Garages are generally protected by a gfi plug. Sometime with power outages these trip. Resetting it can also be an easy fix. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/brandon_a1f2045feb96cdb4
6/17/2015 4:28:07 AM • Craftsman Garage... • Answered on Jun 17, 2015
When i push bottom just clicks
You might want to restate your question with a little more clarity and details.
6/8/2015 7:58:09 PM • Craftsman Garage... • Answered on Jun 08, 2015
2answers
Storm knocked out door opener. There is power to it, but no lights come on on any panel and the lights don't come on. What is the most likely problem? Is there a rest or fuse?
Not sure what your door opener is like but if there has been a local strike, or a power surge , it is possible it has been fried. Probably best to let an electrician take a look at it. Good Luck
6/2/2015 6:05:40 PM • Craftsman Garage... • Answered on Jun 02, 2015
I have a Craftsman 1/2 HP, old garage door opener.The remote was pressed to raise, then pressed again to stop it, in mid-raise....and now neither remotes work at all and the door is stuck half way up.
As Ray stated change your battery and clean the contacts and the button with some alcohol. Check and make sure it works with your wall switch. Lastly the receiver in the opener could be going bad.
4/27/2015 9:07:46 PM • Craftsman Garage... • Answered on Apr 27, 2015
Craftsman Garage Door Opener 1/2 HP Chain Drive Logo
43 questions posted
Top Craftsman Building Materials Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Building Materials
Most Popular Question
need gear fcc id hbw1127 craftsman
  • Building Materials
