20 Most Recent One For All URC-9800 LCD Remote Control Questions & Answers
2answers
I am trying to program my Vizio Universal Remote
Hello, Twomufflers - Doesn't Comcast provide you with a remote to use for the cable box? We have AT&T Uverse as our cable provider and have an AT&T remote control for each of our cable boxes. One of our TVs is a Vizio and we only use the Vizio remote control when we need to change something through the TV menu - like when we change from HDMI input (for cable programs) to AV input to watch a DVD.
12/11/2018 2:56:32 AM • One For All... • Answered on Dec 11, 2018
Motorola codes not working
Check other codes. If you wish to get more details, check this site.http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check this site too. http://electrohelponline.blogspot.com/
5/3/2013 4:18:48 AM • One For All... • Answered on May 03, 2013
I have lost to remote to my SDTV MAgnovox box and it will not power on
try to turn on directly by now. 2( you must find another remote control from r. shack or another stores electronic, or ask to the supplier cable.GOd bless you
9/23/2012 1:26:18 PM • One For All... • Answered on Sep 23, 2012
2answers
What is the codefor an apex digital tuner box trying an rca univeote
If your apex digital tv converter box is an Apex DT250My best guess is: 0749Here is your remote manual:http://www.rockabilly.net/files/manuals/URC-9800.pdf3 digit code: 8644 digit code: 07495 digit code: 52478
8/20/2012 2:27:32 AM • One For All... • Answered on Aug 20, 2012
0answers
The settings button on my urc remote will not
Try another code, sometimes there are several similar ones. Check with One for All.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
3/4/2011 4:00:37 PM • One For All... • Answered on Mar 04, 2011
I have a motorola dct700/us
If you can give the model number of your universal remote, maybe I can give you the code.
Post it here so I can help you further.
2/8/2011 1:43:32 AM • One For All... • Answered on Feb 08, 2011
Remote Codes for Motorola Cable Box DCT700/US
I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
If you take your hand or a thick book and sort of make a hood over the area of the sensor on the cable box and place the remote right up close to the sensor this will help let you know if the remote and the box are working with the code. Also might try turning off the TV or unplug the TV to test and make sure the remote will turn on the box.
Next thing after you determine this is how to block the interference and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
Good Luck ....
1/9/2010 1:54:12 PM • One For All... • Answered on Jan 09, 2010
I lost my rca dtv converter box remote...
Yes, you can I just did it. I was reading everyone logs this weekeng and off to walmart i WENT. Got a 5 dollar remote. rca model rcr312w.
Contacted rca and it was simple as pointing at the dtv , holding down that button and entering in the code for Magnavox and It was on from there. We are happy with RCA.
9/2/2009 12:07:19 AM • One For All... • Answered on Sep 02, 2009
Powers itself off
Cause
• The speaker wires are frayed or sticking out
of the jack, and are touching the back of the
receiver or another set of wires.
Remedy
• Reinsert the speaker wires, making sure there are no
stray strands of wire and that they are inserted fully.
thank you
4/7/2009 12:07:21 AM • One For All... • Answered on Apr 07, 2009
2answers
Universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
4/16/2008 3:55:10 AM • One For All... • Answered on Apr 16, 2008
2answers
Need code for trisonic ts-rc411
I tried all the codes on my remote and none has worked on this remote tsrc411. Help
1/22/2024 7:50:24 PM • One For All... • Answered on Jan 22, 2024
Daenyx model DV833B, I need the remote code for DVD player please?
Question edited to a lot more clarity and fix your broken Spacebar! https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 0872 is the code
Daenyx DVD universal remote control codes (4 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > daen... Mixed Daenyx DVD codes from a single brand of universal remote control. Highlight / Show only codes for: OneForAll x. Sort codes Show color. 4 digit codes:. ..
6/1/2023 5:04:49 PM • One For All... • Answered on Jun 01, 2023
One For All URC-9800 LCD Remote Control Logo
31 questions posted
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • One For All Televison & Video
Most Popular Question
codefor apex digital tuner box trying
  • Televison & Video
