20 Most Recent Simpson PowerShot Commercial-Duty Gas Powered Pressure Washer 3200 PSI @ 3 GPM Honda GX270 Engine And 50' MONSTER Hose #PS3200 Questions & Answers
How many ounces or quarts of oil do you put in the
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
10/7/2010 5:28:44 AM • Simpson... • Answered on Oct 07, 2010
SIMPSON 13SIE-170 UK HANDLE LEAK
6/20/2023 10:13:04 PM • Simpson Garden • Answered on Jun 20, 2023
2answers
How do I remove wheel?
You first have to pry the cap off the wheel with a screwdriver then under the cap there should be either a pin which you pry off or a nut which you loosen.
4/3/2019 10:59:04 AM • Simpson Garden • Answered on Apr 03, 2019
Gasoline simpson preessure washer wont start unless i pull trigger and shuts off when i release trigger
That is what it is supposed to do.
9/26/2018 1:16:45 AM • Simpson Garden • Answered on Sep 26, 2018
Simpson 3000 pressure washer... when trigger is released ,builds pressure so much then can not get trigger to spray. need to shut down release all pressure and restart
There is a pressure release valve in the pump. That pressure release valve is frozen shut (probably due to calcium or lime buildup). Other than disassembling the pump and clearing the calcium mechanically the only thing that I can think of is pouring CLR (Calcium, Lime, and Rust remover) into the port where the water hose connects and hope that the CLR will dissolve the calcium or lime. Pour as much CLR in as you can, connect the hose and pull the trigger and immediately release the trigger. You may have to pour CLR into the hose port several times.
8/12/2018 4:10:26 PM • Simpson Garden • Answered on Aug 12, 2018
I just purchased a Simpson
yep good idea It is a faulty product so there should be no problems for the refund
9/8/2017 9:16:23 PM • Simpson Garden • Answered on Sep 08, 2017
Got a brand new pressure washer Simpson and as I inspect it I notice oil residue in air filter casing holder and some of the paper pleats of the air filter are oily. How do clean this out?
just normal oil vapor from blow by from the ring operation get a new air filter as cleaning filters leads to dusting problems
4/30/2017 4:40:49 AM • Simpson Garden • Answered on Apr 30, 2017
Why does my washer backwash
Because it can!
7/10/2016 1:39:35 AM • Simpson Garden • Answered on Jul 10, 2016
Why does my Simpson pressure washer mega shot V3100 continue to build pressure when I release the gun and stays on high speed
There is a thermal pressure relief valve on the pump that opens when the pump starts to heat up.
7/4/2016 11:53:31 PM • Simpson Garden • Answered on Jul 04, 2016
What oil viscosity and how much on my simpson pressure washer msv 3024
Here's a link to your Simpson manual: http://simpsoncleaning.com/wp-content/uploads/2016/manuals/megashot/MSV3024-I-pwmanual-7107460.pdf No oil is required for the pump. 10W-30 is normally specified for a Honda GCV160-GCV190 engine. You drain the oil by removing the oil cap/dipstick and then tilting the machine on it's side so that the oil can drain out if the oil fill into a container. (Drain when warm so it flows easily). The capacity of the engine is ~18.6 oz. Refill amount is ~12.0-13.5 oz. (either engine). When refilling, add oil and check on dipstick often. To check, press the dipstick into the oil fill, but DO NOT SCREW IT DOWN. Just insert the dipstick in until it contacts the top of the oil fill. The correct reading is between the lower and upper limits marked on the dipstick. (You may have to look carefully to see the marks).
5/17/2016 10:18:42 PM • Simpson Garden • Answered on May 17, 2016
2answers
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
5/21/2015 1:48:20 PM • Simpson Garden • Answered on May 21, 2015
Simpson PowerShot Commercial-Duty Gas Powered Pressure Washer 3200 PSI @ 3 GPM Honda GX270 Engine And 50' MONSTER Hose #PS3200 Logo
4 questions posted
Top Simpson Garden Experts
Sean Wright
Sean Wright
vince
Are you a Simpson Garden Expert? Answer questions, earn points and help others
View Most Popular
Simpson Garden
  • Simpson Garden
Most Popular Question
many ounces or quarts oil put in
  • Garden
