You must measure the 110Vca, Forward and backward.
2) If you do not have the l. switch can be faulty, measure for continuity.
3) Be sure the capacitor for this is Good. look for some wires loose, Retight.
Blessing
[email protected]
cell+whatsAPP:+50588611441
If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD.
Using the hex key, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly
tightened, you should be able to lift each edge of the
walking belt 2 to 3 in. (5 to 7 cm) above the walking
platform. Be careful to keep the walking belt centered.
Then, plug in the power cord, insert the key, and
carefully walk on the treadmill for a few minutes.
Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
GO to www.iconservice.com give your model, and download for freeor go http:// fitness.manualsonline.com for free downloadsincerely. G-d bless youernesto cuadramanagua, nicaragua c.a.
If its side to side, adjust the allen bolts at the bottom front of the
treadmill. If its front to back, and your treadmill is at least a few
years old, the belt is probably stretched and needs replacing. You can
get a quote for a new belt at http://www.treadmill-world.com/parts-manuals.html
If the treadmill is a Reebok 8050 they have manual for it at iconservice.com. This compamy manufactures a wide variety of treadmills and the only way for sure to find the correct manual because they have the assembly instructions that canbe useful in the disassembly procedure.
Reebok
For questions about parts, service, user's manuals or non-working products for Reebok Home Fitness equipment, please call our Reebok Customer Service Department at 1-877-994-4999.
If it's like many treadmills there should be 3 or 4 phillips screws across the front of the motor cover and 2 or 3 underneath. If this is a fold up model, tip the top front back to the walking board. Use your foot as a brace to keep the unit from sliding when you tip it backwards. You now need a # 1 and 1/2 or 2 10" phillips screw driver as the screws that hold the hood down are recessed. On some models there is a screw going thru the underside of the right and left side of the frame. If this is the case, you can fold up the walking deck to see them.
In order of most likely cause. 1) Worn motor belt needs to be changed. Rear roller bolts need to be tightened as the walking belt has too much slack(2-3 inches lift on the edge of the belt in the middle on each side) 3) the nylon pulley on the front roller is slipping and a new roller is needed.
