see the video attached. Lube the rollers bearing too front+back. test the drive belt motor, for to loose or faulty belt and repair and replace.However you must test the input voltage terminal motor, see my personal TIPS , if there are the motor is faulty.Test the output voltage control board, for input voltage terminal motor, if there ARE not voltage , the board is faulty.God bless you
Hols the stop button and the speed decrease button down while inserting or attatching the key (magnet). There should be a "d" on the screen, press the incline down button and it should go away. As soon as it disappears, your done. Just pull the key off and your display will shut off.
The problem is most likely a malfunctioning incline motor. It is still under warranty, therefore you can contact iconservice.com and they will send a technician to your home to install the new motor. Contact them through their website at iconservice.com and they will be able to help you. Thank you for using fixya and please let me know if there is anything else I can do for you.
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when: 1. the question is unclear, incomplete, or poorly worded... 2. the question is mis-categorized - so the correct experts aren't viewing it... 3. the question requires an answer for something that cannot be explained online adequately... 4. specific training, tools, or equipment are required to avoid injury or death... 5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason. Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are... $ 9.99 answer for one question. $12.99 Live Real-Time online chat or premium e-mail support. $29.99 Live Real Time phone support Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership. Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft * then try to walk on it and see if the white mark separates * if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place * if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix. * if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws. Tighten each one the same amount such as 1 full turn to start with. see if you can now walk without it slipping. If not then tighten 1-2 more turn on both sides. If after 2-3 full turns it is not tight enough I would recommend replacing the walk belt.
Hi, you have a failed control board panel, which the keypads are attached to. Once you press the keys and they don't respond, then you need to change the board..
Pretty much the bearings have flatten if you are getting a clunking sound these are normally sealed bearings and it is better to replace the roller. Call Icon Fitness @ 1-800-999-3756
If you have power to the machine, but no buttons are functioning or just a few of them, then the main control panel or board is bad. This is like the brain of the machine. You may have to test the circuits with a volt and ohmmeter to figure out which buttons are not responding. If your not getting power to the motors then it is very likely the control board is shot.
