20 Most Recent
Epic 600 Mx Treadmill Questions & Answers
We have a 600 mx
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Epic T60 treadmill motor on 1-2 sec. then go off
Here are a few things you can try to troubleshoot the issue:
- Check the power supply and make sure that the treadmill is plugged in and receiving power.
- Check the fuse or circuit breaker to make sure that the treadmill is not tripping any electrical circuits.
- Make sure that the motor and controller are properly connected and functioning correctly. You may want to check the wiring and make sure there are no loose or damaged connections.
