20 Most Recent
Epic 450 Mx Treadmill Questions & Answers
Treadmill flips breaker after staring up for about a second?
An overload causes the breaker to open. First: The motor might have a bad field winding or internal partial short: Second: A bearing on one of the rollers may be shot? You can check for this by simply walking on the tread. It should move, if not there is a bad bearing. A far out reason is that the breaker is opening at less than rated current. (failed breaker). If you have a long heavy duty extension #16 gauge wire (18 gauge minimum), try another outlet that you know is on another breaker.
Turns on but will not respond when keys are pressed
Dear Sir:As you must understand the treadmill use the most advance electronic design.Please do the following:1)use contact cleaner(radio schack or whatever)2)Inspect the fuse.3)Tight the ribbon cable INSIDE from the keypanel(not the console)4)Tight the connector from the console going to the main board motor.check this block diagram for to see if anything can help you in the treadmill. If you do not resolve your problem. can be board console vs . main board motor.
God bless you. sincerely.ernesto a cuadramanagua, nicaragua
Display functions on right side don't work as
Hi drnelson3,
This problem is as a result of a bad control panel. The control panel controls all the functions of the unit it accepts commands and executes them. Often times it would accept a command but not execute as a result of malfunctions on the control board. This is why a times it comes on and doesn't function. The control board is not totally bad but suffers from partial failure therefore the problems.
Best solution is to get the control board replaced this can be done by any service repair personnel or simply contact the nearest dealer for a repair person.
Hope it helps.
Thank you for using FixYa.
Motor has been checked ok when is turned on it
You must see with a volt meter, if you are getting arequired power. It can be weak motor or defective motor controller issue. The interiormotor links are loose or the belt is dried up use some basic lubing by grease.If the problem still exists then you may need to replace motor controller ormotor.
Console to elevate and control
you will need to test the red wire coming to the console with a volt meter to see if you are getting the required 9-12 vdc if you are replace the console, if not replace the controller. Now if just the buttons are not working replace the console. You can get a console from iconservice.com
Epic T60 treadmill motor on 1-2 sec. then go off
Here are a few things you can try to troubleshoot the issue:
- Check the power supply and make sure that the treadmill is plugged in and receiving power.
- Check the fuse or circuit breaker to make sure that the treadmill is not tripping any electrical circuits.
- Make sure that the motor and controller are properly connected and functioning correctly. You may want to check the wiring and make sure there are no loose or damaged connections.
