20 Most Recent
Astra Car Alarm And Remote Starter, 4000rs2w1 Questions & Answers
Astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
I have an astra remote
Check the battery in your remote first. Then check all fuses for the Astra. Sounds like the main one at the battery.
I thought the battery died on keyless unit however
sounds like you may have a bad switch. sometimes switches stay permanently open. if that is the case, the switch needs to be replaced. if you have a multimeter ;you can check the switches to see if they are open or not. if it reads less than mega ohms, the switch is probably bad.
TRYING TO INSTALL REMOTE STARTER, INSTRUCTIONS
go to bulldogsecurity.com they have wiring color codes and locations for your vehicle.Also they list any special relays that you may need for factory security.
Please be sure to rate if this helps you out
Hi i put a astra
Check what happens when you power up the starter. If
Starter doesn’t start and parking lights flash:
3 Times - Engine RPM not detected (check tach wire and/or perform tach learn procedure) Hood Trigger is active (hood is open, wire is shorted to ground or pin switch is
defective)
4 Times - Brake Trigger is active ( Brake switch input is shorted to ground or incorrect)
5 Times - Unit is in Valet (service) mode, and start is disabled.
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
