20 Most Recent Haier HVF042 Wine Cooler Questions & Answers
My wine cooler is stuck on 74 degrees even though I have followed the instructions to program it to a cooler temperature
Once I unplugged, pulled away from wall, cleaned components area, plugged back in, all was back to normal!
10/27/2022 6:48:45 PM • Haier HVF042... • Answered on Oct 27, 2022
0answers
I need to know where
Number 19 in this photo is the control boards location=> HVTS18DABB Parts Breakdown
and if you need the user manual click here=> HVTS18DABB User Manual Please rate this if helpful and should you have more questions please ask, Thanks Sea Breeze
5/10/2011 12:35:47 AM • Haier HVF042... • Answered on May 10, 2011
2answers
I have a Haier 42
i think it needs a new thermostat as the contacts have fused together so its not turning off the compressor ,but in all honesty i have never changed one on this model so i have no product knowledge of how to strip it to change it ,but stand back have a cup of tea and a good look and dare say its not as daunting as you first think ,i would imagine a universal type thermostat will do the job yes ok it might need a bit reworking to fit it but it will work .
11/17/2010 12:01:07 PM • Haier HVF042... • Answered on Nov 17, 2010
2answers
My wine fridge is not
From what you are describing you have most likely lost the refrigerant (freon) from the system due to a leak.
This is not a simple repair. It would require someone to tap into the system and find where the leak is, repair the leak and recharge with refrigerant. If you are under warranty yet it would be repairable, if not you will have to weigh the cost of repairs vs a new model. A typical sealed system repair will cost around $400.00 depending on which component needs replaced.
The tubing you are referring to is called a process tube, it is used at the factory for charging the unit. Crimps in it are there when they seal the system after filling.
5/24/2010 3:23:21 PM • Haier HVF042... • Answered on May 24, 2010
The cooler is not cooling, the temperature keeps
there are few things that might be the reason why is this happening.
1. Check the fan
2. check if there is any leak(oil leak) from your tubes or piping
3. have your compressor check, yes it maybe running but the question is thus it gives enough compression to provide the temperature you desired
11/5/2009 8:56:32 AM • Haier HVF042... • Answered on Nov 05, 2009
Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
3/25/2009 12:00:15 PM • Haier HVF042... • Answered on Mar 25, 2009
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
9/3/2008 5:35:36 AM • Haier HVF042... • Answered on Sep 03, 2008
8answers
Wine refrigerator
You can control its temperature by its thermostat control knob.
8/22/2008 3:53:02 PM • Haier HVF042... • Answered on Aug 22, 2008
0answers
Motor never stops.Inside temperature too cold
it has to be the thermostat,solution,replace stat.have the new one ready,as you take out the old one,and its hard to go wrong if you take your time,good,Luck eire!ps. motor won't stop unless stat cuts out!!
12/16/2007 3:40:18 AM • Haier HVF042... • Answered on Dec 16, 2007
0answers
0answers
Haier HVF042 Wine Cooler Logo
27 questions posted
Top Haier Furniture Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Haier Furniture Expert? Answer questions, earn points and help others
View Most Popular
Haier Furniture
  • Haier Furniture
Most Popular Question
need know
  • Furniture
