20 Most Recent Haier BC112G Wine Cooler Questions & Answers
Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
11/24/2018 1:53:46 PM • Haier BC112G... • Answered on Nov 24, 2018
4answers
Haier wine cooler
Haier BC112G service & user manual: To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
9/11/2017 12:04:28 PM • Haier BC112G... • Answered on Sep 11, 2017
BC112G Wine Celler Not Cooling
Open the terminal box ontop of the compressor. Check if there is a thermistor inside. If there is, check the continuity. If the continuity is alright, check the winding resistance of the compressor. If the winding resistance is good, then the fault is in the controls.
5/2/2017 1:13:03 AM • Haier BC112G... • Answered on May 02, 2017
2answers
Magic Chef Wine Cooler Model #MCWC50DBT will not
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
4/22/2016 6:59:54 PM • Haier BC112G... • Answered on Apr 22, 2016
Breezair unit freezs up in my wine cooler---- why.
Does it run constantly? If so, an easy test fix is to go to WalMart and buy a timer that cycles in half hour intervals. Play with the on/off settings and see if that stops it from freezing up. May be the thermostat, which is a fairly easy fix. May be low on Freon.
6/14/2014 4:06:50 PM • Haier BC112G... • Answered on Jun 14, 2014
Cant seem to get to set other then 81 degrees
try replacing the thermostat. It is a metal tube.
5/28/2014 12:15:26 PM • Haier BC112G... • Answered on May 28, 2014
I have a Haier wine
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
4/23/2014 8:37:24 PM • Haier BC112G... • Answered on Apr 23, 2014
Very cold can not regulate the temperature
try replacing the termo sensor.
4/23/2014 8:29:57 PM • Haier BC112G... • Answered on Apr 23, 2014
0answers
Buzzing noise
Be the first to answer 4/15/2014 3:22:10 AM • Haier BC112G... • Posted on Apr 15, 2014Be the first to answer
Haier BC112G Wine Cooler Logo
217 questions posted
Top Haier Furniture Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Haier Furniture Expert? Answer questions, earn points and help others
View Most Popular
Haier Furniture
  • Haier Furniture
Most Popular Question
wine cooler capacitor pop up but not
  • Furniture
