20 Most Recent Philips HD-5661 Questions & Answers
2answers
Espresso machine
Sometimes the rubber seals on these can be very "stuck" after not being opened for a while - about the best way to free them is to pour a little hot (near boiling) water around the outside of the lid to soften up the seal, make sure you are trying to turn it the right way (anti-clockwise) and give it a little force. You can help prevent this in future by lightly greasing the seal with a tiny bit of vegetable oil - sunflower oil works fine but most should do the job. if the rubber seal looks very distorted or cracked then take it to a hardware store and see if they can find something the right size or try philips support from the same link below. get the user manual here (sorry not available in english, but is available in most other main languages) http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=AEN&cat=KAP_COFFEEMAKERSANDKETTLES_CA&sct=CK_ESPRESSOMACHINES_SU&session=20070307124515_83.54.34.75&grp=KITCHEN_APPLIANCES_GR&ctn=HD5661/90&mid=Link_UserManuals&hlt=Link_UserManuals Hope this helps :)
3/7/2015 7:16:49 AM • Philips HD-5661 • Answered on Mar 07, 2015
0answers
I have recently acquired an unused HD5179 Espresso
I too have the same problem wth HD5179..i took it to philips service centre...they barely looked at it and said SORRY NO SPARES for this model.It seems in INDIA philips does not have facilities to service home use exopresso machines...a sad state of affarirs
8/10/2013 6:02:34 AM • Philips HD-5661 • Answered on Aug 10, 2013
0answers
0answers
0answers
0answers
Philips HD-5661 How does Foam maker work?
I recently acquired the same model of espresso maker. I have found that you have to turn it on, and give the water time to heat up before attempting to use the steam function. If you turn on the steam knob too early, it will shoot out a stream of water, so you have to wait till the water is hot enough... probably 3 minutes or so. I'm assuming that you already know that you just place the steam spout into a mug of milk to both heat it up and create foam simultaneously. -Tim
1/2/2008 10:40:16 PM • Philips HD-5661 • Answered on Jan 02, 2008
My Philips Espresso EP3221 make too light coffee.
If the brewed grounds are wet, the brew head needs all new seals. These machines need dealer service at least once a year depending on use. They don't tell you this when you buy them. It need stripping down, cleaning and all new seals, reprogram and test. https://www.google.com/search?q=Philips+Espresso+EP3221+make+weak+coffee and also https://www.google.com/search?q=Philips+Espresso+EP3221+grounds+are+wet ..
4/20/2024 7:23:03 PM • Philips Coffee... • Answered on Apr 20, 2024
Philips LatteGo Coffee Machine. The water light stays on even if the water tank is full.
Limited help here, but these machines need dealer service every 6 to 12 months depending on use. Of course they don't tell you this when you buy them. https://www.google.com/search?q=Philips+Lattego+water+light+stays+on ..
12/10/2023 4:54:08 PM • Philips Coffee... • Answered on Dec 10, 2023
Seaco Syntia hd8837. Why is it stuck in an endless descaling loop?
Descaling Problem SOLVED! Folks, I really hope this helps a lot of you. I too encountered the dreaded descaling problem where it gets stuck in a loop and never finishes. I thought the machine was toast and see so many reviews that people experienced this and had to return the machine. I tore apart the machine and figured out the issue and the super simple fix! What happens is the water level sensor does not know it is running out so when the tank empties due to running dry, it never completes the cycle. Where the water basin goes, if you look at the back lower down, you will see a small rectangular protrusion. This is the water level sensor that works by measuring capacitance. You know how sometimes your machine runs completely out of water and you have to prime it with the tea/hot water button? This is why! When you put the tank in full, water splashes over the edge and down the back. It coats the outside rear of the tank and the sensor with water so the machine thinks it still has an adequate level of water but then all of a sudden runs dry. The FIX: Take a paper towel and dry off the water level sensor and the back of the tank. When you put the tank in, do not fill it too high and put it in gently to avoid water spilling out. Simple as that...fixed! https://www.fixya.com/support/t7525311-machine_seems_stuck_in_descaling_mode and videos and help from Philips Press and hold (for about 6 seconds) the hot water button until the descaling light turns off. https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00Uzvq3eDBHCFOUx_2MVtsuTL0uPQ%3A1606349189530&ei=hfG-X6TtH5Wq1QGCjanwDg&q=Seaco+Syntia+hd8837+stuck+in+endless+descaling+loop
11/26/2020 12:10:29 AM • Philips Coffee... • Answered on Nov 26, 2020
I have descaled my Philips Syntia espresso machine regularly, but no water is coming out. I think there must be limescale buildup internally. How can I get the covers off to see the hoses?
First, I'm not a Philips technician. Also don't recommend De-scaling of table top machines UNLESS the MFR provides the de-scaler and recommends it. Several things can prevent the water flow in these small machines. It's probably the vibration pump but suggest following the following list to check if everything is in order. - Water not getting to machine or not sensing that the water tank is already filled. * There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up). * Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement. * Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years). * Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments. Aloha, ukeboy57
1/19/2018 2:14:22 AM • Philips Coffee... • Answered on Jan 19, 2018
I bought my senseo philips HD7825. I loaded the water then plugged it in then I added the coffee pod. However, the power light kept blinking (slowly) as though it is heating up. But it is not heating.
Hi Quite possible the boiler has failed. You would need to disassemble to check (with a multimeter) if the boiler heater elements are a continuous track from one terminal to the other. Boilers often fail - else you have a electronics problem somewhere that will require a tech person check out. The other thing boilers can do is to develop an earth leak between the heater element itself and the outside of the element - this will cause the machine to shut down your house's power supply if you have an Earth Leakage Safety Switch installed in your meter box. Given this was an inexpensive machine and uses rather "odd bod" pods it may be time to consider something more 'common' like a Nespresso, Aldi or the Cafitaly style of capsules. I especially like the Cafitaly capsules as they have more coffee than Nespresso, have 2 internal filters, can be refilled with ground coffee (I reseal top with wide cellotape) and can be refilled at least 4-6 times before they should be thrown away. Instead of around 30-50c a cup, refilled capsules costs me about 9c a cup - I get about 100 capsules out of 1Kg (2.2 pounds) of coffee.... beat that. Cheers Mike
12/11/2017 4:25:52 PM • Philips Coffee... • Answered on Dec 11, 2017
Philips HD-5661 Logo
14 questions posted
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
David Kassin
David Kassin
Paula Hamilton
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Philips Coffee Makers & Espresso...
  • Philips Coffee Makers & Espresso...
Most Popular Question
espresso machine
  • Coffee Makers & Espresso Machines
