20 Most Recent
Cobra CPI 1000 DC to AC Power Inverter Questions & Answers
88 ac volts at receptical
Sounds like the transformer is done. Have a big switch on the DC side, to turn it off when not in use. Being on all the time burns it out.
I bought a cobra cpi
got a cobra cpi 480 inverter it keeps beeping everything runs but produces no power
Can i run a ps3 from this inverter in my peterbilt
I would tend to say yes you could since I have ran a PS3 on a much small unit in a car....I would suggest that you try a hair dryer first...if it can handle the amps from that then it will be safe to run the PS3
Is it possible to repair my Cobra 1500w to 3000w peak power inverter?
As the Cobra 1500w inverter is constructed analogous to a high-frequency "switching" power supply, it is not recommended to modify it to exceed original specifications. For any inverter intended for applications exceeding 2000W transient peak, it is highly recommended to use a low-frequency "true-sine" inverter. Your Cobra inverter is designed for low-deman applications, and is insufficient for high-demand applications.
5/18/2018 6:35:07 PM •
Cobra...
Answered
on May 18, 2018
Cobra power inverter is blinking "default". Why?
I don't know the model you have but green usually means it's on an working. Red means you have a voltage overload or it got to hot an needed to shut down until it cools off. Hope this helps
7/19/2017 6:14:13 AM •
Cobra...
Answered
on Jul 19, 2017
