20 Most Recent
Krups Ea9000 Barista Espresso Machine Questions & Answers
Krups EA9000 Dosing of beans.
Plug it in, turn it on and then within 3 seconds touch each of the 4 corners on the touch screen in this order Top left, Bottom right, Bottom left, Top right that should open up the settings options for you, follow your nose after that.
What does code 26 indicate?
Check the float in the tank, if it is not floating up from the bottom then jam something plastic underneath it to activate the water level sensor. You can either continue to use it like that ans check water level before you brew or buy a new tank, there is no repair for a float.
How do you remove brew unit
I have done XP9000, this may be similar. Remove side cover, operate lever on side of exposed brew unit and pull brew unit out with the handle. You can only do this when machine is in normal 'at rest' position. Unit will not come out in any other position.
