20 Most Recent
Thermador PODC302 30" Double Electric Wall Oven 4.7 cu. ft. True Questions & Answers
I have a Thermador CM302BS oven and it will beep just once about every 30 minutes. No lights are on or anything?
If your Thermador CM302BS oven is beeping once every 30 minutes without any visible indication on the control panel, it's possible that the oven is experiencing an error or malfunction that is not being properly displayed. Here are some steps you can take to troubleshoot the issue:
- Check the owner's manual: Consult the oven's owner's manual to see if there are any troubleshooting tips related to the beeping issue. Look for any error codes or messages that may be related to the beeping.
- Reset the oven: Try resetting the oven by turning off the circuit breaker that powers it, waiting a few minutes, and then turning the circuit breaker back on. This can sometimes clear up temporary issues with the oven's electronics.
- Check the oven's self-diagnostic system: The Thermador CM302BS oven has a self-diagnostic system that can be accessed by pressing a series of buttons on the control panel. Consult the owner's manual to see how to access the self-diagnostic system and check for any error codes or messages.
- Contact a repair technician: If you are unable to resolve the issue using the above steps, it's possible that there is a more serious issue with the oven's electronics that requires the attention of a qualified repair technician. Contact Thermador customer support or a local appliance repair service to schedule a service call.
It's important to address any issues with your oven promptly to ensure that it is operating safely and efficiently.
Error code F64 on lower
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
