20 Most Recent
Sony Ericsson Z550A Cellular Phone Questions & Answers
Need unlock code for sony ericsson z550a for a
If you get error message as PIN blocked. Unlock?"
You have entered the wrong PIN code too many times.
You need to unlock your phone using the PUK (PIN Unlocking Key) code. Your PUK code is provided by your network operator.
If you get error message as Insert correct SIM" You have inserted a SIM card that is not supported. Insert correct SIM card, or contact your Service Provider for a SIM unlock code.
If you get error message as Phone locked" or "Enter PIN" Your phone
is locked and you need to unlock it with your personal PIN. The default PIN is '0000', but you or your network operator may have changed it.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
What is a puk
My dear:Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly SolvedBut:Don't try to enter a PUK code without knowing the right one.You need to call your service provider to get this code. It can be as many as 8 digits, and it is random. If you enter too many wrong codes, you can permanently damage the device. So Please You Go to Service officeand Get the Duplicate Sim From Office OpraterSame Your No Problem will Solved
IT HAS A BLANK WHITE
your phone's software is corrupted
try to flash the main or it difficult for you then go to sonyericsson service center
I need a puk code 4 lg gb220
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At
the link below you will be directed to a tip i wrote on how to recover
your PUK code.
Click HERE to navigate.
Kind regards
Lock123
I need the PUK code
When you have entered a wrong pin number three times the phone asks you for a PUK number. The PUK code is generally eight digit number. The PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to buy a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number. You can find the PUK code is in your SIM card documentation Starter Pack. If you do not have this then contact your phone service provider. Your cell phone service provider can give you the PUK code once they have confirmed your identity to prevent any stolen SIM access.
Need puk code for sony
This problem is very common and most users think that it's related to phone, which is not true, this is only with your sim card and is for security reason. We can't use software or hardware or other tricks or methods to unlock it, the only solution is from the Service Operator/Network Operator.
If you keep entering random codes/unknown numbers several times, your sim card will be rejected and will not be usable anymore.
Your only solution is to call the service provider (Network operator's customer care), ask them to give you your puk code, they'll promptly give it to you after few inquiries to make sure you are the true owner of the sim card. (there's no charge as well, and if you call from the same network' sim card to the customer care, you'll not spend/pay a penny).
There's no other alternatives, or no other options that you can get the code, so don't play around, rather make a call to the customer care of the sim card network operator and get the code.
I wish you good luck.
Thanks for using FixYa.
I accidently put a puk code and i a i dont know
the puk code is supplied by your provider after you have entered the wrong sim card pass code more than 5 time.
if i am understanding this correctly you actually need a PUK code.
You can either go to your provider store near you and they will unlock your sim or you can go onto their website and get a puk code, but not all providers offer the puk code over the net.
Sony ericsson ck131not sccept sim card
What message are you getting on the screen when you turn the phone on? Is it recognising there is a sim card there but not letting you use it? The most common reason for this is often a 'Locked' handset. Most networks set the phones the sell to only work for their sim cards. Most specialist phone retailers can usually Unlock the handset for a small fee.
If it isn't recognising that there is a card there it will either be a faulty sim card or a faulty phone.
