CasioWhy do I have problems printing with my thermal printing calculator ... The buttonor switch can control rounding off to a certain number of decimal places. ... When you press the [M/EX] key, it toggles between conversion mode and memory ...... The letterwill appear in bold so that you know it is a hex digit and not a variable.
Casioplace where it will not get into the hands of small children and accidentally ... leaving the calculator in direct sunlight, near a window, near a heater or anywhere ...
Change the display mode. Press SHIFT MODE 6 then the number of desired digits after the decimal point. Alternatively, press SHIFT MODE 8 and select one of the "Norm" modes. This is all in the "Specifying the Number of Display Digits" section on page E-8 of the manual.
On the fx-115ES, to convert a single result to decimal press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Press [SHIFT][MODE][6:FIX]. You are then prompted to enter a number between 0 and 9. The number you enter fixes the number of decimal digits your results will have. If you press 0 all numbers will be rounded. Setting two or three decimal digits should be reasonable for most situations.
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hello
[Shift][Setup][6:Fix]4 displays result with 4 decimal places. But if number is too small you will lose significant digits and may have a null value.
In that case you use [Shift][Setup][7:Sci]4 displays results in scientific notation digit.4digitsx10^(exponent)
