SOURCE: Cannot create playlist
You must be in MTP mode, create a sync list in WMP, then drag the play list to the sync list of the e-280. it will create the new playlist on the e280.
SOURCE: how do I create playlists for iriver H320
I too wanted playlist and found it out for v 1.25 K. I am not 100% sure about playlists for version 1.30E sorry, but you can try.
This is how I make playlists. Plug your iriver into your computer. Make a folder on your iriver, call it whatever you want. I called mine playlists.
Create a textfile in the folder, call it whatever you want and give it the extension the same as winamp gives. I think it is .m3u? Maybe .m3p? Anyway, find that out.
Open the file in notepad and put the path to the song. eg:
\music\rock\linkin park\numb.mp3
Add as many as you want one under the other. And make as many playlists as you want. Then unplug your iriver and let it rebuild. In music mode, you have to not be playing a song, so stop any music, then just press the A-B button and a list of the playlists should appear. Select one and away you go. If the press A-B does not work, try holding it. I can't remember as i havn't used mine for a bit.
Sorry I can't be most specific about your version. Or the extension of the file, I wrote a program myself to do the work for me. Check to see if it works for you, if you want a copy of the program I can send it to you. it is in .Net 2 so you will need the the framework installed.
SOURCE: iriver mp3 player
Try this. Worked for me.
http://forums.whirlpool.net.au/forum-replies-archive.cfm/751249.html
Cheers
James
SOURCE: Iriver E10 Reseting Options
can i suggest you try rockox http://build.rockbox.org/ this will give you more than the regular ole iriver software.
but if you really want to start fresh back up the e10 iriver software, format you e10, re-install iriver software, add your media back (i've done this with my kids ipods also..and it works like new)
good luck............feel free to rate if helpful
SOURCE: iRiver E150 Shuffle
Starting from the main menu.
Select Music.
In Music mode: Press and hold the > button to view the Options screen.
Select Play Mode.
Under Play Mode: select Shuffle or Shuffle + Repeat.
You can also look this up in the E150 manual. Download the English.zip file from next page:
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=985&page=1&cateCode=03
Unzip the zip file, with WinZip or WinRar, to view the manual in pdf format, that can be opened with Adobe Reader.
Testimonial: "Thank you so much. I have been scouring the internet for days with no answers. It worked perfectly, very happy now. Thank you! (:"
