Ovens Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bake cycle wont work gas kenmore with electric controls you can set temp it goes to preheat and nothing happens broiler works and all the tops work
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Aug 03, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636859
Points
7414
here is a tip i wrote covering that
What the problem is when your gas oven ignitor glows,but no heat for the...
MessageRate.ThreadID = 9947539; MessageRate.ProductID = 0;
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 • Amana Ovens
Kenmore gas oven model 91136519 from 1992 . The stove top burner work as well as the oven broiler. But the bake mode of the oven will not come on. What could be the problem?
Faulty temp. control...The variable temperature portion is faulty, but broiler function FULL ON GAS is ok...Replace the Temp control assembly.
Jul 01, 2010 • Ovens
Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 • Ovens
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
My Kenmore Electric oven quit working.
PUT POOP ON THE WHATYAMACLIT AND SEE WHAT HAPPENS
Dec 28, 2008 • Ovens
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Smoking Kenmore
Hello oliver909
Welcome,
You said,Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
If your afraid to use it, do not hesitate to call service. Nobody wants a fire!
Huuum
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
2helpful
Kenmore Oven Mod# 665.75012104
hi. thanks for the question .i would replace the bake igniter. that will solve your problem. happy graduation .thanks the appliance doc
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
