20 Most Recent Kenmore 30464 / 30465 / 30469 Gas Single Oven Questions & Answers
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Kenmore 30464 /... | Answered on May 20, 2019
Hello Melanie!
Does the oven not heat? Are you able to program the oven at all? or is the display or read out blank?
Do you see any error codes? What youre experiencing may be control board related. If so, Fixyourboard.com can help. Feel free to respond to these questions here -- info@fixyourboard.com
Best,
Megan
Kenmore 30464 /... | Answered on Jun 06, 2017
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Kenmore 30464 /... | Answered on Apr 10, 2015
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Get any and all numbers you can find from the original controls. Also make a note as to the length of dial shafts, direction they turn, shaft size and "flat" location when in off position and the temperature range and whether high to low or low to high.
Then go to this site and search for exact or something that you could live with. . . . http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19145&pID=18668&mode=categorysearch . Hope this helps!!
Kenmore 30464 /... | Answered on Feb 02, 2015
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore 30464 /... | Answered on Jan 21, 2014
unless its really really old no pilot
hot surface igniter
if oven its coming on or temp is low change the igniter
Kenmore 30464 /... | Answered on Nov 20, 2013
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
195 questions posted
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Ovens
  • Kenmore Ovens
Most Popular Question
ignitor oven comes but gas release
  • Ovens
