SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
SOURCE: need instructions to reset sub dials on Nautica Chronograph watch
Pull out crown to the first click and push and hold pushbutton at 2 or at 4.
SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
SOURCE: Heuer chronograph second hands will not reset to
Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
SOURCE: Hello, I have a Seiko Chronograph Titanium 100M.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SEIKO watch manuals. Rate me, please
