20 Most Recent
Oakley GMT OAK0531 Wrist Watch Questions & Answers
Timesetting on Athletic Works wristwatch
I have a AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
I have an Oakley Blade watch with a
If you go to their web site (www.oakley.com/) you will see that the illustration a watch similar to yours (it is a Blade II) and shows a metal one.
If you use the store locator to find one that is near you and speak to them about changing the strap.
Needs battery replacement
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Here's my suggestion. Take it to the jewelry dept at
Walmart. Do you have one where you live.
They'll replace for free - Battery $8
Watch how they do it with their tools and you'll know how to do it yourself in
the future.
Good luck
Change military time on aw205
When in the time set mode press the A button, this will toggle from military time to standard. I discovered this through trial and error, not in instructions.
CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
Problem with second hand
I need to know what type of oakley is this .. i mean what model .. because they have different specifications..
12/31/2007 11:49:57 AM •
Oakley GMT...
Answered
on Dec 31, 2007
