Heres how to restore your MPD24 factory defaults using the Vyzex software: 1. Plug in your MPD24 with USB cable, and then open the Vyzex software. 2. Click File > Open 3. Select Factory SET.SQS, and cliHow to factory reset mpd18 - pre3.jpgit. 4. You should now see BFD Lite aHow to factory reset mpd18 - pre4.jpg details on the Vyzex MPD image. 5. As long as you're on the DATA tab, you should see a PUT SET buttHow to factory reset mpd18 - pre5.jpgable. Press it to transfer the factory presets to your MPD24. 6. An overwrite warning wilHow to factory reset mpd18 - pre6.jpgplayed. Press YES to overwrite your damaged MPD24 presets with the factory presets. You'll see a progress bar filling up for about 10 seconds, and then once it disappears, that's it! You're all done - Enjoy!
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
