If your battery is a year old should replace it a new one, When battery reach in a year the ampere rate is getting weak. And to prevent that you should always check the battery water level if your battery is a maintenance type. Feel free to send feed back best regards.
Sir try to check the battery using a tester, select the dc voltage and check the dc output of your battery, put the red testing rod to positive of the battery and black to the negative, then try to accelerate your scooter and observe the tester dc output if going down but be sure the wheel of your scooter is not touching the ground. To be sure that your battery is still in right ampere rating. Good day sir and best regards i hope that this may help.
The batteries are not a year old. They are sealed batteries, therefore I do not know what you are talking about.
