If you want to modify your IP address,then you can follow the steps given below
Go to start->Run->type
ipconfig/release
ipconfig/renew
You can also modify your IP by resetting your modem if it is
dynamic.After changing it you can check your new ip address on the site Ip-details.com .
Use notepad to write the following:
{IP;2,192,168,001,201'}
{IP;3,000,000,000,000'}
{IP;4,255,255,255,000'}
{IS;1,09100'}
{XJ;Termine'}
and print it to your printer
These will change your
IP adress
Gateway
your submask
activate and deactivate the port with an adress at 9100
and at the end display Termin?
respectiveley
