20 Most Recent
Toshiba TEC B-SX4 Thermal Label Printer Questions & Answers
Ribbon error 1
have to check:
- Adjusment value.
- The ribbon rolls must turn correctly.
- Check if the detecting wheels are not full of grease.
- Check the rbn rwd values.
Poor print quality
Several checks:
- Just saying...Ribbon sometimes is placed in the wrong sense and it doesn't print.
- Verify the settings at printer driver. Download a powerful Driver from here:
http://www.nicelabel.es/downloads/nicelabel-designer-pro/?uid=10004, and test the darkness option by printing with different measures at each time.
- If that doesn't work, we can check it again, but you should first test this options.
Does anyone know how to rectify the TEC B-SX4 head
This excess temperature may be caused by a temperture detector.
Ther are two detectors on a Toshiba Tec Printer.
- On the print head.
- In the top part of the label sensor mecanism.
You cna check if they are working when going in the adjust set parameter setting.
You can read Head temp and air temp
If one of them is not working you will not be able to adjust the temperature. Worst you'll have the message Head excess temperature message.
Tec sx4 network
Have you checked the port Number.
Tec use port number 8000 and the standard default in windows 9100. Either you change on your printer or in the driver.
How can i adjust the label feed
Firstly the length of the label must be correctly set.
- When activation forward wait on parameter, you can adjust the feed value.
- else you can adjust the feed value in the driver.
Sx5 ribbon error
Use an appropriate Ribbon.
Check that the slits on the ribbon detection is not full of dirt.
check that your ribbon motor parameters are correctly set.
