Remove the battery and check the voltage on the battery , If this is low then the battery can be defective or there is no charging to the battery.So remove the battery and connect the charger to the laptop, then check the charging voltage on the battery terminals on the laptop. If there is no voltage then the main board charging circuit is defective as the charge indication is also absent.
This might require some good testing within the board and must be attempted only if you are good in checking circuits using a multimeter/test instruments.If voltage is present then the battery can be defective.
Probably the charger is not working right. Please check with with a spare charger or borrow with someone to check. if the laptop switches on the charger has the problem. Buy a new one with same specification to avoid further problems. and please dont forget to vote my answer with the thumbs up symbol below. thank you.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
