IR port --> in AS just go to "file\connection settings" then tick in the checkbox "enable connection serial cable or IR to this COM port" and choose from the drop down menu "IR port" BT port --> go to the BT manager on your PC, then "advanced config" and click onn thee nail "local services" - double click on the "BT Serial Port" and you will be prompted to the "properties" window that gives you a drop-down menu where you can choose the # of the COM port. You can also edit numbers in the System REgistry, but this requires proper care. I think the foregoing is sufficient for you
