20 Most Recent Navigator Amcor Amigo 4300B GPS Receiver Questions & Answers
2answers
Google Navigator will not pick up my bluetooth GPS readings
Just using the 'Settting manully' and set the port and bardrate
12/17/2016 7:51:51 AM • Navigator Amcor... • Answered on Dec 17, 2016
How do I configure Bluetooth code for I phone
It should say in the instructions on the thing you are trying to connect to
7/6/2014 7:55:14 PM • Navigator Amcor... • Answered on Jul 06, 2014
I have a new blue
Ann,
When you go to the BlueTooth option in the Menu, you will find an option where by you make it visible to all. Please slect this and then the phone would be visible to all BT devices. Also there is an option to search for all BT devices within range. Select this and see your GPS. Select GPS and PAIR with it from the options. Once paired you will be able to use GPS and phone together.
3/2/2011 11:05:02 PM • Navigator Amcor... • Answered on Mar 02, 2011
I was pairing nokia 2760 to my amcor 4300B. I
Well you may press the Sleep / Wake up and Hardware Reset Switch to reset your amcor GPS this switch is located on the back side at center position. After resetting it again try to connect it with your phone and let us know if further you have the same issue.
Good Luck!!
Thanks
1/30/2011 4:49:18 PM • Navigator Amcor... • Answered on Jan 30, 2011
Amcor 3990 GPS navigation device screen backwards
If your screen is actually installed backwards take it back and exchange it for new one, but if the screen is not actually installed backwards then go into the settings screen on the gps unit and find the orientation section, this will change the display to something a little more readable to you. And as a side note some of these things look like they should be straight up and down but they actually designed to work sideways, gives you a wider view and the manufacturer a little more screen room to put more information onto the screen.
1/14/2010 6:55:32 PM • Navigator Amcor... • Answered on Jan 14, 2010
We are flying to Palm Springs, CA in Nov. and want
If you live in the us you dont have to upload anything unless you just want the new maps.(if the case then unlock the sd card)All of the 3900 sold in the us had all states on the sd card.
If you dont live in the us then get a cheap new sd card and try the process you did before again.
I do not know if the amcor servers are still online cause i purchaced the new software that had the maps on it(IGO 8) whitch could be an option if all else fails
10/16/2009 7:21:08 PM • Navigator Amcor... • Answered on Oct 16, 2009
Someone gave me a AMCOR NAVIGATION 3900 THE
contact Navigator and buy new maps, Maps are consumables and are not free.
8/14/2009 6:03:07 AM • Navigator Amcor... • Answered on Aug 14, 2009
2answers
Re- setting my GPS Navigator... amcor amiga 3900
not able to change the date and time
8/14/2009 5:55:11 AM • Navigator Amcor... • Answered on Aug 14, 2009
2answers
Gps
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=1053107930%201053307939&bop=And&ActiveSearchResult=True&Order=PRICE
Cheapest is 5 bucks!
Hope this helps! :)
5/27/2009 3:03:49 AM • Navigator Amcor... • Answered on May 27, 2009
My 4300b do not have multimedia function
My 4300b have only Navigate, Settings and Bluetooth buttons.
I modify IGOPATH.TXT file located in \FlashDisk folder on 4300b :
[modules]
Bluetooth = "icons/bluetooth.bmp", "\\windows\\bluemain.exe"
Settings = "icons/settings.bmp", "settings", 1
Multimedia = "icons/media.bmp", "Multimedia", 0
Navigate = "", "\\Flash Disk\\igo\\igopna.exe"
[Multimedia]
Picture= "icons/picture.bmp", "\\windows\\PhotoViewer.exe"
Movie= "icons/movie.bmp", "\\windows\\player.exe"
Music= "icons/player.bmp", "\\windows\\xplayer.exe"
Explorer = "icons/files.bmp", "\\Windows\\explorer.exe"
and now I have a Multimedia Button.
Verify to have PhotoViewer, XPlayer, Player exe in \Windows folder.
I use info from http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=110237&whichpage=15, freeboy post.
1/30/2009 11:23:09 PM • Navigator Amcor... • Answered on Jan 30, 2009
My xgody 520 navigator keeps resetting in a loop can you help
Try to calibrate, and then use.
1/29/2019 3:54:57 PM • Navigator GPS • Answered on Jan 29, 2019
Navigator Amcor Amigo 4300B GPS Receiver Logo
25 questions posted
Top Navigator GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Navigator GPS Expert? Answer questions, earn points and help others
View Most Popular
Navigator GPS
  • Navigator GPS
Most Popular Question
new blue
  • GPS
