Brookstone Theraspa Turbo Massager Logo
Anonymous Posted on Aug 27, 2008
Pillow support I want to buy a memory foam neck pillow. How do I choose one?
Sam Walker
Level 2:
Habit-Forming:
New Friend:
  • Expert 36 Answers
  • Posted on Oct 19, 2016
Sam Walker
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
36
Questions
0
Helped
14846
Points
189
This is very innovative way to get a good night sleep.
"After trying numerous ergonomic pillows to help alleviate neck and shoulder pain, this one is by far the best! I have been sleeping with it for about a week now and have had a significant reduction of neck pain, tension headaches, and shoulder pain. Thank you so much for a great product!"
Chiropractic Neck Pillow for Extra Support Sunshine Pillows
Body Pillow Expert
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 01, 2015
Body Pillow Expert
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2425
Points
30
There are many things to consider before buying a neck or body pillow like Your Sleeping Positions, The Fit Size, Allergy Issues, Purpose of Using, and more. Here a complete guide on how you can choose the best suitable pillow - Best Body Pillow Reviews
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Aug 27, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
Helped
724286
Points
8771
Memory foam neck pillows come in many varying densities, sizes and shapes. Usually, when you seek out a chart for memory foam pillows, they give you suggestions based on your height only. While that is a good start, you need to also consider the following: Do you sleep on your side, back, stomach or a combination of all three? Do you prefer a small, medium or large pillow now? What kind of pillow are you used to sleeping on? Is it firm, medium or soft? Do you suffer from neck pain? Knowing the answer to these questions will help you in selecting the right memory foam pillow, or may suggest that you would prefer a different pillow altogether. For example, if you sleep on your stomach, a neck pillow might not work at all. You might want to check out a memory foam pillow that's shaped like the standard pillows we all grew up using.
COULD THE THERAPEUTIC PILLOW BE THE BEST PILLOW FOR NECK SURGERY?
The therapeutic pillow could be a good option for neck surgery. It is made of an environmentally friendly recycled foam that is medium density, so it is not too soft or too hard. It has a special section that supports the upper back called a thoracic wedge. This can help those with neck and upper back pain when back sleeping, as well as provide support and comfort when side sleeping.
Ultimately, your surgeon should determine the best pillow for neck surgery based on your specific case. However, the therapeutic pillow is a good option to consider.
Here are some other things to keep in mind when choosing a pillow after neck surgery:
  • The pillow should be firm enough to support your neck in a neutral position, but not so firm that it is uncomfortable.
  • The pillow should be the right height for your sleeping position. If you sleep on your back, you will need a thicker pillow than if you sleep on your side.
  • The pillow should be made of a breathable material that will not trap heat.
  • The pillow should be hypoallergenic to prevent dust mites and other allergens from building up.
If you have any questions about choosing a pillow after neck surgery, be sure to talk to your doctor or a physical therapist.
Legs for Enso Sleep Systems please?
Contact them direct Lisa
Enso Sleep Systems - Home
http://www.ensosleep.com Enso memory foam mattresses, pillows and mattress foundations are built to stay clean and keep your sleeping environment fresh. We are devoted to creating ...
Adjustable Bases
Once you've chosen your Enso Mattress and Enso Pillow, find ...
Enso Products
Choose from our line of memory foam mattresses, foundations ...
Contact Us
Contact Us. Please provide any information that can help us ...
Owner's Manuals
Select the owner's manual that matches the adjustable base ...
Jul 04, 2022 • Baby Gear
1helpful
6answers
HOW TO FIND PILLOWS?
Choosing The Best Pregnancy Pillow For Mums-To-Be The importance of having the best maternity pillow at your disposal during the various stages of pregnancy is often overlooked by many mothers-to-be. One of the main contributing factors which affect spinal health and a sound nights sleep is the dreaded back pain during pregnancy. Unfortunately it is extremely common, and according to spine health experts it's estimated that a massive 50-80% of women experience some form of lumbar pain throughout the trimesters which also carries on post birth.
You can find it here Best Pregnancy Pillow For Mums Reviews The Best Choice For You
2answers
My surgical Neurologist prescribed an ORT 13100M my use in recovery of fractured vertibre in my neck. A 2 1/2 by 10 inch expandable cloth sleeve came packed in the box with the cervical collar. How is...
Hello Les, If you notice the shape of your collar takes on the anatomical contours of your neck when wearing it. The 2 1/2 x 10 inch sleeve that came in the box is a extra synthetic covering to be used over the foam collars, most likely by seperating the end of the cloth and sliding the collar into it. It works as a barrier between the skin of your neck and the actually foam collar for absorption of sweat and dirt. This will keep the actually collar clean and can be taken of and washed periodically.
10answers
Neck pillow Question
J Pillow is the best-selling travel pillow and the winner of British Invention of the Year in 2013. Read why this is the best comfortable neck pillow you can use on the go. Pillow Review with Pros and Cons
3answers
Neck Rest help
Amazingly, there is! This mp3 memory foam neck pillow comes with built-in speakers. Simply plug in your portable audio player, lean back, relax, and enjoy. The Memory Foam MP3 Neck Pillow is available from Amazon.com for $36.99 or from the Smarthome website for the same amount. You should be advised that because it plays your music on speakers, this thing might interrupt other people.
1helpful
2answers
Massaging neck rest question
The massaging neck rests usually offers you two relaxation therapies: variable speed vibration massage to customize massage intensity and heat. Some of this devices even have a "comforting sounds" option (which makes relaxing sounds). Besides that most of the massaging neck rests offers the same featurs. They wrap comfortably around your neck and shoulders, supporting your head in a comfortable position (Usually - memory-foam filling and a soft fabric cover). Hand-held control adjusts the vibrations to your specific comfort level, without having to stop the massage. Includes plug-in AC adapter, or you can use four AA batteries
Top Brookstone Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Brookstone Health and Beauty Expert? Answer questions, earn points and help others
