Arrow T59 Wire & cable staple gun Logo
Anonymous Posted on Aug 27, 2008
Staple Gun Troubleshooting
How does a staple holds when you use a staple gun if the staple doesn't bend like when using a normal stapler?
  • 4 more comments
  • Anonymous Mar 12, 2014
    source for plier type staple guns
  • Anonymous Mar 14, 2014
    Loading a Josef Kihlberg HJ0 staple gun
  • Anonymous Mar 16, 2014
    won't shoot staples, air leak top housing.
  • Anonymous Mar 28, 2014
    gun is about 25yrs old and recently will not eject stsples.
  • Anonymous Mar 29, 2014
    where do I get staples
  • Anonymous Mar 31, 2014
    I cannot find to buy staples 8mm A:4-14 B:11.2-11.5 C:1.1-1.3mm
Geo S
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 07, 2015
Geo S
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
6863
Points
26
Strip staples and brads intended to be used in wood, are coated with a very thin film of lacquer. When fired into the wood the lacquer melts from friction and acts as a glue which is why they can be very hard to remove.
A
Anonymous
Why does my staple gun shoot double stables and also doesn't do all the way in soft wood?
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Aug 27, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
Helped
724302
Points
8771
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
3 Related Answers
Anonymous
  • 32 Answers
  • Posted on Nov 26, 2008
SOURCE: Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Anonymous
  • Posted on Dec 05, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
swDemonDog
  • 233 Answers
  • Posted on May 27, 2010
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
Arrow TacMate Staple Gun Model T50X1220. I just purchased it new. I loaded it with Arrow T50 staples, numerous sizes, but nothing exits the gun.
Question edited for clarity and typos.
Question moved from Air Tools and Compressors.
It is always a misfired staple jamming at the end or incorrect loading of staples.
How to Troubleshoot a Staple Gun
Hunker https://www.hunker.com > how-to-troubleshoot-a-stap...
Troubleshooting a staple gun such as the Arrow T50 is often as simple as unclogging a jam in the mechanism. This happens when a staple lodges inside the tool, ...
Common Staple Gun Problems and How to Fix Them
Tool Nerds https://toolnerds.com > common-staple-gun-problems
Arrow PT50 - that utilizes external power to propel the staples, meaning effortless trigger operation. Misfiring or Clogged Hammer. The signs of a ...
why-aren't-my-staples-going-all-the-way-in-when-i-use- ...
Arrow Fastener https://arrowfastener.com > arrowfastener
Reason #3: Not keeping the staple exit point flush to surface when firing. ... Duty Staple Gun takes more grip strength to fire than our TacMate staple gun.
How do I load the stapler?
Search Results
    Stanley electric stapler/brad nailer - YouTube
    ? 5:06
    https://www.youtube.com/watch?v=Zbgt2UXpS-M
    Dec 29, 2013 - Uploaded by Tindlez
    How to load staples and brad nails in Stanley electric staplermodel TREE550 ... Stanley SharpShooter Manual Staple and Brad Gun review ...
    Stanley Electric Staple/Nail Gun (TRE550) - YouTube
    ? 5:04
    https://www.youtube.com/watch?v=6JTZJjQ3wlA
    Jan 5, 2015 - Uploaded by HowToWith GEO
    This video tests the Stanley electric stapler and nail gun. Model TRE550. This video will test both staples and brad type nails. ...Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. Unpack Guy 43,106 ...
    Safety Tips for an Electric Stapler : How to Load Staples into ...
    ? 1:01
    https://www.youtube.com/watch?v=dMsdmYBoojU
    Feb 5, 2008 - Uploaded by expertvillage
    Learn how to load staples into an electric stapler in this free educational video ... Stanley Electric Staple/Nail Gun (TRE550) - Duration: 5:04.
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
1helpful
How do you load staples into the Power Shot Model 5700M staple and nail gun? There is no manual in the package despite direction on the side of the gun to read it!
I have owned a Black & Decker Powershot before. Throw it away. They are **** . Stick with a Arrow or Craftsman. I didn't like the Black & Decker and gave it to a friend that was looking for a staple gun. He threw it away ! Worst excuse for a staple gun I've ever seen. Awkward to use and preforms on a scale of 1 to 10 , doesn't even hit 1 !
I am trying to staple screen on 1.5 inch pine frame with 1/2 staples, but I have to set them with a hammer. Am I expecting to much or is there a way to adjest it to run them in the who way /
I have found that staples will set well only if I use the palm of my hand to hold the front of the stapler down tight against the material as I operate the handle.with my other hand. Without holding it down this way the stapler tends to recoil a bit and the staples don't set all of the way. If that doesn't solve it for you, you could try using 3/8 staples, since the screen material is of negligible thickness. Good luck, Al K
How do i load the gun with staples
There is a clip at the lower rear of the stapler--lift this clip upwards which releases the staple tension device which is the clip, a rod, a long spring, and a 'U' shaped clip on the far end. Pull this device all the way out, insert one length of staples into the slot that is revealed, then reinsert the tension device until the small clip re-locks at the rear of the stapler frame. One staple ejects per squeeze of the firing lever--hold the nose of the stapler firmly to the material to allow penetration of the staple. Hope this helps!
1helpful
How do i load the staple gun?
1 Hold stapler upside down.
2. Release black plastic catch at rear and pull out.
3. Drop staples into bottom of gun, with open side up.
4. Push black plastic catch closed and latched.
wallyp
The stapler is fixing two staples instead of one at a time.what can be the defect and how to correct it?
First check and make sure the proper staples are in the gun. Also check and make sure the stapler is clear and no jammed or broken staples are in the gun. If this is a desk stapler make sure the plate is locked in for the staple to hit and bend the ends out or in. if all this is working the driver or the piece of metal that pushes the staple out may be bent. If the stapler is new take it back if it is not a minor problem and get a new one.
Staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Top Arrow Tools & Hardware - Others Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
