Just installed a ev system , similar drive with yours, different sensor, go to setup and reset the unit to factory settings and then enter the correct parameters for your boat . Good luck and fair winds
I suggest you sell that before you have serious problems and no one will buy it. Yeah, that's what I would do... after all the two best days of a boat owner experience are the day you buy it... and the day you get rid of the money pit.
SOURCE: my Ray Marine ST 1000
the worm gear that is inside the unit may need to lubricated,, remove the bottom case and lubricate gears and shaft with a teflon or silicone based lube. also on my sailboat when this happened I found that I needed to re-calibrate the unit - take the boat out into a very calm and open water and ' spin the boat ' in CAL mode ( this will re-orientate the internal compass ).
have fun on the water and have a great night,
c...
SOURCE: I have a Raymarine ST2000+ tiller pilot. In going
Hi!
I can't see being 5 degrees off line much of a problem as far as the sweep is concerned.
I'm fairly sure that when you do your 1 1/2 to 2 SLOW circles that the tillerpilot will correct itself to read closer to your actual compass heading as well.
Hope this helps you out.
Happy Boating!
