20 Most Recent Raymarine Fluxgate Compass Module Questions & Answers
I installed a Raymarine compass
If I were troubleshooting this, I'd manually adjust the orientation of the compass sensor until it matched the true heading. Once that was done, I'd move it side to side to ensure it's changing in the correct directions. If not, the unit could be upside down. Let me know how this turns out.
5/21/2017 10:33:14 AM • Raymarine... • Answered on May 21, 2017
We have a Raymarine ST8001 autopilot system that
compass needles are affected by iron objects and can also be affected by field magnetism generated by current flowing through a wire .Bilge pumps , winch motors are heavy current drawers and they could affect the compass operation while the voltage is low the field of the magnetism around the wire can influence the compass heading so check for any electronic apparatus wiring close to the unit ( radio , radar etc it may be necessary to run the powers wires in an insulated sheath ( like coaxial cable or other insulated power cables) around sensitive equipment talk with marine equipment installers to get better ideas as to prevent interference with the compass
4/4/2017 11:17:37 PM • Raymarine... • Answered on Apr 04, 2017
The Raymarine ST8002 Smartpilot the unit powers up but does not work when the auto mode is selected. The hydraulic motor does not engage when a course is set. What could be the source of the fault?
According to a post on the Raymarine forum, this error message could indicate an issue with either the steering, the drive unit, the rudder reference unit (if fitted), or the course computer . The post suggests a few tests that you can do yourself to figure out which item is causing the issue. I suggest that you try the following steps: Check the connections between the ST8002 SmartPilot and the other components of your autopilot system. Check the calibration of the ST8002 SmartPilot and the other components of your autopilot system. Check the hydraulic fluid level and the hydraulic pump pressure. Check the hydraulic pump motor and the hydraulic pump solenoid valve. If none of these steps work, I recommend that you contact Raymarine customer support for further assistance.
11/20/2023 9:03:39 PM • Raymarine... • Answered on Nov 20, 2023
How do I connect my garmin 741sx with my raymarine St 4000 with nmea 183
To connect your Garmin 741sx with your Raymarine ST 4000 using NMEA 183, you will need an NMEA 0183 interface cable to connect the two devices. Here are the steps to follow:
  1. Obtain an NMEA 0183 interface cable that has the correct connectors for your Garmin 741sx and Raymarine ST 4000.
  2. Connect one end of the NMEA 0183 interface cable to the NMEA output of your Garmin 741sx.
  3. Connect the other end of the NMEA 0183 interface cable to the NMEA input of your Raymarine ST 4000.
  4. Configure your Garmin 741sx to output NMEA 0183 data. Refer to your Garmin 741sx manual for instructions on how to configure NMEA output.
  5. Configure your Raymarine ST 4000 to receive NMEA 0183 data. Refer to your Raymarine ST 4000 manual for instructions on how to configure NMEA input.
  6. Once both devices are configured, the data from the Garmin 741sx should be transmitted to the Raymarine ST 4000 via the NMEA 0183 interface cable.
2/23/2023 5:01:41 PM • Raymarine... • Answered on Feb 23, 2023
Raymarine C70. Como cambiar la pantalha de modo diurnos a noturno ?? en el Raymarine C70.
Question edited for clarity.Question moved from Cars and Trucks to Raymarine.Adjusting the display lighting The display has two distinct color palettes, for day and night operation. You can alsomanually adjust the backlight level.Note: The display lighting is a local setting and will therefore only affect the individualdisplay on which you are working.Day/night operationTo select the day/night mode of operationhttps://www.manualslib.com/manual/138190/Raymarine-C-Series.html?page=30#manual
8/3/2022 6:36:50 PM • Raymarine... • Answered on Aug 03, 2022
I want to mount a sonar transducer for my raymarine dragonfly-4 on my 16 foot aluminum boat where do I mount it Thank you
on the transom outside of the boat silicone the bolt holes
10/29/2021 12:36:07 AM • Raymarine... • Answered on Oct 29, 2021
Raymarine c120 classic intermittent no data source
"Finally convinced him that **your** specs requiring the 4c cable at those lengths was correct" You know we are Fixya and not Raymarine? We just have a Raymarine category for handy filing of questions and answers. This question needs a factory service department technician on the phone. As a boat owner, who doesn't have radar, and reading your post carefully, I would suggest the connection at the top of the mast. It is far more hostile up there, and it has been up there a long time.
7/10/2021 9:20:46 PM • Raymarine... • Answered on Jul 10, 2021
Need Manual for Navico WP5000
get ie here -
http://hem.passagen.se/beg_stockholm/wheelpilot_manual-no_pic.html
8/3/2018 9:46:52 PM • Raymarine... • Answered on Aug 03, 2018
I have a Raymarine Axiom system on my boat. Can you help me.
Check with Raymarine. Model number would be of use. http://www.raymarine.com/view/?id=10125 Raymarine Manuals Documents
6/21/2018 12:27:41 PM • Raymarine... • Answered on Jun 21, 2018
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
1/3/2018 10:37:57 PM • Raymarine... • Answered on Jan 03, 2018
How do I calibrate my raymarine st2000+ auto helm
Hi David. A little late, but the information you require can be found here: http://www.raymarine.com/view/?id=346 Hope it helps someone else out. -Steve Raymarine ST1000 ST2000 Tiller Pilots
12/31/2017 2:47:32 AM • Raymarine... • Answered on Dec 31, 2017
What's the scoop on the compass placement for raymarine EV1 sensorcore
It replaces the fluxgate compass and adds a few Moore sensors to the system, such as acceleration an deviation sensors to give a m?re intelligent data to the processor
11/24/2017 4:16:08 AM • Raymarine... • Answered on Nov 24, 2017
Where can I download a raymarine c 90w user manual
On manualslib.com or on the Raymarine site itself...
9/25/2017 7:03:36 AM • Raymarine... • Answered on Sep 25, 2017
Raymarine ST6002 Smartpilot Alarm Message ''Seatalk Fail 2''
Very possible that the Wind instrument has a defective Seatalk interface - it happened to me. You could try your Wind in another boat, just connecting it temporarily to the Seatalk Bus - if it jams those it is the problem Your autopilot should have a separate Course Computer such as the 100, 400, S1... somewhere. Some models have two SeaTalk busses, and the recommended installation is to use one bus for the 6002 control head alone, and the other bus for instruments etc, so a SeaTalk fail on the instrument bus will not disable he Autopilot. I retired my boat this way (after the dealer took the one-bus shortcut). The real solution is to have the Wind instrument fixed. The cheapest work-around is to cut the yellow SeaTalk wire between the 6002 and the Wind, so that the Wind instrument gets power but does not affect the data bus. That should let the AP and Wind each work normally and independently (no Wind-angle mode on the AP). Raymarine have a forum you should join for more info and help.
9/11/2017 1:28:04 PM • Raymarine... • Answered on Sep 11, 2017
Raymarine Fluxgate Compass Module Logo
Popular Tags
7 questions posted
Top Raymarine Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
View Most Popular
Raymarine Boating
  • Raymarine Boating
Most Popular Question
installed raymarine compass
  • Boating
