Scosche Industries Scosche Slc4 Speaker High Level Converter Logo
Aaron Groves Posted on Aug 25, 2008
Wiring diagram For Scosche FA1-3A (adds RCA outputs to factory radio w/no RCA outputs)
  • rachaelf00 Dec 04, 2008
    NEED THE WIRING DIAGRAM
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5039
Points
Anonymous
Level 1:
  • Posted on Jan 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5039
Points
Go to this thread they have a diagram that might help.http://forums.genvibe.com/zerothread?id=14516
2003 Hyundai Tiburon. Can I get a wiring diagram for the radio?
Question edited for clarity.
Question moved to model category.
2003 Hyundai Tiburon Car Radio Wiring Chart - MODIFIEDLIFE
MODIFIEDLIFE https://www.modifiedlife.com > 2003-hyundai-tiburon...
Our 2003 Hyundai Tiburon radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 2003 Hyundai Tiburon Radio Wiring Diagram ...
Hyundai Tiburon 2003-06 - Scosche
Scosche https://www.scosche.com > media > guides PDF AMPLIFIER LOCATIONS: VEHICLE MAYBE EQUIPPED WITH FACTORY AMP. LOCATED ON DRIVER SIDE PANEL ON FRONT OF REAR. SPEAKER. W ...
Anyone have a 2012 Chevy Silverado radio wire diagram so I can install my subwoofers to a factory radio?
The factory radio does not offer RCA outputs. The easiest thing would be to tap into the rear speaker wires at the point where they go up the C pillars.
I have a keenwood indash dvd player i want to hook my amp to it but it dont have rca jacks so how do i do it
If your indash radio does not have RCA outputs, you can do two things. You can purchase a line level converter and hook it to one of the rear speakers. This will allow you to tap into the speaker wire, then convert the signal to RCA. Then you plug your RCA cables in there. The other (my recommendation) is to purchase an "add an amp" wiring harness. This harness will install between your radio and vehicle harnesses. It will have RCA output and remote wire. Then you run those back to your amp and there you go. You can find these at the scosche or PAC websites. You can also try www.crutchfield.com
I want to install a subwooper into my toyota altis 20007 model but theres no audio out connections in the car audio. how can i fix this problem. i want a diagram on the car audio system of the toyota altis...
You can visit scosche or PAC to see if an "add an amp" wiring harness is available. It will adapt to have power, remote turn on, and RCA outputs. If this is not an option, you may need to look into installing an aftermarket radio. hope this helps.
5helpful
2answers
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
1helpful
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
