20 Most Recent Scosche Industries Scosche Slc4 Speaker High Level Converter Questions & Answers
0answers
2answers
Wiring diagram
For Scosche FA1-3A (adds RCA outputs to factory radio w/no RCA outputs)
5/17/2016 4:30:18 PM • Scosche... • Answered on May 17, 2016
0answers
0answers
0answers
Scosche Frosted Clear & Black Audio
What is the problem with it? Need more details please.
11/8/2012 3:53:05 AM • Scosche... • Answered on Nov 08, 2012
0answers
0answers
How do you hook up
Be the first to answer 8/14/2011 6:25:54 PM • Scosche... • Posted on Aug 14, 2011Be the first to answer
Need a wiring diagram for
you can download the instruction manual for free at the following link.
http://www.scosche.com/car-audio/product/999
6/6/2011 6:03:23 AM • Scosche... • Answered on Jun 06, 2011
2answers
Wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
2/17/2011 3:39:26 AM • Scosche... • Answered on Feb 17, 2011
I bought a system and this scosche fa1-3a came
This device is used to connect the speakers out puts to an amplifier.
Usually a car stereo speakers are high volume out puts and it can damage the sound (distortion) at the time to connect an amplifier so the best way with less distortion is hooking up this device to low the volume and get a clean sound to be amplified
12/3/2010 9:29:16 AM • Scosche... • Answered on Dec 03, 2010
Schoche converter trouble
yes , if you do not make your connections right you could probably damage the high to low, verify that all the wires you tapped into where speaker wires
7/16/2009 2:26:07 PM • Scosche... • Answered on Jul 16, 2009
Sub hits backwards, hi low level converter?
I ran into a similar problem installing a sustem in a Mazda RX8. He had BOSE speakers which operate at a different range. We had to purchase the Rockford 3sixty.
6/23/2009 1:29:01 PM • Scosche... • Answered on Jun 23, 2009
Scosche FIA-3A Tie into rear spekers of a 300C to
Hello herg1076,
Here's a link to www.modifiedlife.com which will have a page showing the color codes for your vehicle wiring. The 2008 Chrysler 300 rear speakers are shown as follows: Left positive is Dark Green/Tan, Left negative is Dark Green/Gray, Right positive is Dark Green/Brown, and Right negative is Yellow/Green. Other models and other years will be different, so be sure that you browse to the correct color codes for your specific vehicle.
Hope this helps.
4/22/2009 1:21:54 AM • Scosche... • Answered on Apr 22, 2009
Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
2/17/2009 2:06:12 AM • Scosche... • Answered on Feb 17, 2009
Scosche Industries Scosche Slc4 Speaker High Level Converter Logo
36 questions posted
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Scosche Industries Car Audio & Video
Most Popular Question
need wiring diagram
  • Car Audio & Video
