Common causes of this are improper level setup. You MAY be overdriving the inputs. Use the pad buttons to limit the input for higher output devices. Saturating the input(s) will cause bad distortion. Observe if any of the clip indicators are coming on. If they do, then use the pad buttons. If they still come on due to very high output device, you MAY have to use an external attenuator. Every mixer has different characteristics and some can accept a wider inout range than others.
