I will buy the Home Depot 1 1/2in rollers, which are concave, and grind off the sides to make a 1 1/4in convex wheel, just like the original.
Ron C, I bought the parts you had listed from the Home Depot website of the 1-1/8" rollers and they did not work. The original rollers were 1-1/2" rollers or 38mm rollers with a 10mm center bore. I have looked everywhere I can think of for these rollers and they are nearly impossible to find.
SOURCE: Hello, People I have a Tunturi
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
FitnessRepairParts.com has parts lists for two different versions of the Tunturi 202 depending on the serial number / manufacturing date, although I don't see any wheels in those lists:
Tunturi R202 (After S/N 025840)
Tunturi R202 (S/N 025840 to 150000) Manufactured 1990-1994
You can also search by part number at the top if you have a part number from your manual. And you can also click "Contact Us" at the bottom and ask them directly... they usually respond pretty quickly.
SOURCE: Worn seat wheels on Tunturi 202 need replacing
FITNESS REPAIR PARTS
unfortunately they charge too much. by the time you buy 4, you paid for 1/2 a new machine!!
