It is flashing a error code, check the link to diagnose your code.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
4 red blinks of the power (standby LED) is for a cooling fan error.
Listen on the back right hand side of the TV (facing the TV) when you turn it on, to see if you can hear the fan running. You can grab a flashlight and see it and can also feel it blowing air. It is possible you can pull the back and clean it, without having to replace the fans. There are two fans by the way, second one is right in the center of the back of the TV. Appears like dust building up on fans can slow them enough to cause this error. Hope this helps!!
